all 4 cylinders has low compression
Old Apr 28, 2010 | 06:13 PM
alexso15's Avatar
Help guys i have an evo ix and i got it tuned by mellon and it didn't put out the right HP #s. Then i went home and checked my compression and it turned out that i had low compression in all 4 cylinders. The car drives fine but it is not putting out the right hp with all the parts i put on. Do u guys know the problem?
parts that i have on:
tomei pon cams
down pipe
exhaust
injen piping (all)
xs eng intercooler
And i only put out 265hp and 279 torque. I know i should be putting out more.
Old Apr 28, 2010 | 07:35 PM
stackhouse's Avatar
how many miles on the motor? how many psi per cyl? And this is unrelated to low compression, but have you checked for boost leak?
Old Apr 28, 2010 | 07:38 PM
detroit pistins's Avatar
Originally Posted by stackhouse
how many miles on the motor? How many psi per cyl? And this is unrelated to low compression, but have you checked for boost leak?
+1
Old Apr 28, 2010 | 07:43 PM
wizzo 8's Avatar
How many times did you crank the motor over per cyl?
Old Apr 28, 2010 | 07:46 PM
TurboTim06's Avatar
do a leakdown test
Old Apr 28, 2010 | 07:47 PM
mifesto's Avatar
any chance you are on low battery? compression test on low batt can potentially throw off results
Old Apr 28, 2010 | 07:51 PM
wizzo 8's Avatar
Very true
Old Apr 29, 2010 | 07:37 AM
alexso15's Avatar
the engine only has 46000 miles on it. i am running only 19psi where it is happy with little knock., the higher psi we went the more knock we got. I havn't checked the battery yet but it does crank every time. i turn the key.
Old Apr 29, 2010 | 07:39 AM
alexso15's Avatar
Originally Posted by detroit pistins
+1
before getting it tuned me and mellon did a boost leak test.
Old Apr 29, 2010 | 07:54 AM
FLASH1970's Avatar
Originally Posted by TurboTim06
do a leakdown test
Do a lead down test. That will show you where the air is going.
Old Apr 29, 2010 | 09:52 AM
eb66's Avatar
You still haven't posted the compression numbers...
You may want to try a wet compression test. It will tell you if your rings are shot.
Old Apr 29, 2010 | 09:59 AM
Strictly Modified's Avatar
Originally Posted by eb66
you still haven't posted the compression numbers...
+1
Old Apr 29, 2010 | 10:14 AM
T2Small's Avatar
Did you hold the throttle open while cranking? Wet compression test might be enlightening assuming you can get the oil to edges of the piston. If all four are just a little low, I'd actually just run it as-is. I've seen more than one 4G63 make good power with less than ideal compression across the board.
Old Apr 29, 2010 | 05:48 PM
mifesto's Avatar
if you have low compression in all four cylinder, its often other issues including faulty tool, faulty procedure or weak battery....
its extremely rare to get low compression on ALL the cylinders. variance between cylinder is more important then pure numbers
Old Apr 29, 2010 | 05:55 PM
apagan01's Avatar
what are the numbers man ??
are they low butr consistant ??
give us the full data so we can help.
