all 4 cylinders has low compression
Old Apr 29, 2010 | 07:38 PM
alexso15's Avatar
Originally Posted by apagan01
what are the numbers man ??
are they low butr consistant ??
give us the full data so we can help.
after 15 revolution 100 psi dry and 150 psi wet in 7 revolution.
Old Apr 30, 2010 | 05:32 AM
eb66's Avatar
That sounds most likely to be blown rings. Its only supposed to go up a little with oil, not 50 psi. Did you add the right amount of oil, like a cap each cylinder? Too much oil and it could be artificially inflated (doesnt sound like its the case, just letting you know)
Old Apr 30, 2010 | 07:31 AM
Mellon Racing's Avatar
it's got to be bad rings when the psi jumps up that much. Maybe it was running around overly rich for a long time or just had bad oil in it. Hard to say but I think it may be time to have the engine freshened up. Might be a good opportunity to put a buschur 2.0 or 2.3 in there
Old Apr 30, 2010 | 10:42 AM
alexso15's Avatar
Thats what we figured but wasnt sure. Thanks Chris. About that buschar 2.0 or 2.3 I dont know, maybe only if i had a tree that grew money lol..
Old Apr 30, 2010 | 10:55 AM
I wonder how much blood plasma is going for these days
Old May 15, 2010 | 08:41 AM
EVO8STI's Avatar
any chance your equipment is off a bit?
Old May 15, 2010 | 02:07 PM
SkipDMan's Avatar
Mivec engines always have low compression numbers due to the cam timing during cranking. The cam profile is not active until the car is running. In addition it needs oil pressure to operate correctly.
Just throwing that out there. You should post your number as stated above.
Old May 15, 2010 | 02:19 PM
kanyonkid's Avatar
+1... IX's read lower compression than 8's but like eb66 said, 50 psi difference from dry/wet testing is not good. Do a leak down test.
Old May 16, 2010 | 10:02 AM
SkipDMan's Avatar
I didn't catch that ^ Sometimes if you use too much oil during the wet test it will considerably raise the compression.
Old May 19, 2010 | 04:27 AM
fit2.0's Avatar
I was going to say head gasket, but once you posted the diference with the oil I say piston rings. Is your car burnig oil? And check all the sparkplugs for color they always tell the truth.
Old May 22, 2010 | 06:32 PM
Negative-1's Avatar
As stated before, a leak down is the best way to figure out what is going on.
Poopy
Mar 16, 2014 03:31 PM
vinnieg
18
May 8, 2012 01:48 PM
Pssst
Mar 29, 2012 04:21 PM
outlawedracer
09+ Ralliart Show and Shine
Oct 17, 2009 07:36 AM
WcEVO2
Sep 30, 2007 11:12 PM
