Knock Count
Old Jun 19, 2010 | 01:36 AM
EvoVIII808's Avatar
yeah my commander will show 18 counts, but with FC Edit, get 6 counts on Advance Knock, have not looked at the basic knock.
Old Jun 19, 2010 | 01:42 AM
haseeb's Avatar
[QUOTE=xska;8416839]power fc has fuel cut on rev limiter so it knocks when you hit rev limiter.
if you are making over 400-450hp there is a little chance that you may blow head gasket
y do u think i may blow head gaskit ?
any thing wrong u think ?
Old Jun 19, 2010 | 10:39 AM
EvoVIII808's Avatar
[QUOTE=haseeb;8418453]
You have smoke at full boost, oil in radiator fluid?? if not then you not blown, but can check the tightness of your head studs. After my install i was getting some crazy knock because they weren't tightened down enough.
Old Jun 23, 2010 | 09:59 AM
haseeb's Avatar
no there is no smoke nor oil in radiator ..
every thing is gr8 ..
i just see 80 count of knock when ever i hit rev limiter or when ever i launch ..
other wise there is not more that 17 count of knock ..
just wanted to confirm y i see 80 count knock or is it the false knock ...
thanx
Old Jun 23, 2010 | 12:49 PM
EvoVIII808's Avatar
could be from what was mentioned above, but i dont know.
Old Jun 25, 2010 | 03:52 PM
xska's Avatar
You can try lowering your ignition timing on last cell before fuel cut by 2-3degree.
It should lower your knock count.
Last cell meaning, your running boost ( 2.0kg=30000 1.8kg = 28000) at last rpm column.
deadstockkpomp
Aug 17, 2018 01:13 PM
rcb213
Cobb AccessPORT
13
Feb 13, 2015 07:04 AM
deadstockkpomp
Jul 8, 2012 03:06 PM
Windstorm
Apr 23, 2012 05:59 PM
EVOXTIMES
Apr 12, 2010 05:58 PM
