Not boosting correct after removel of MBC
Old Jun 10, 2010 | 09:10 AM
Carter19's Avatar
Question Not boosting correct after removel of MBC
Ok i installed some cheap MBC from ebay and it ended up to suck, broke something idk it dident work and everything was hooked up right, so i take it back off and run my vacum lines back the way they were stock. but im only boosting 14 and it wont spike pass that. Before when i was stock it was spiking 19ish an tapering back down to 16ish, what happened? i unplugged my battery and nothing happened.
I have the wastedgate an turbo nipple "t" together running to the stock vacum thing (forgot the name at the moment) and then the other side of it running back to the intake. im sure thats right.
Any clue why i dont have all my power back?
Old Jun 10, 2010 | 09:17 AM
MR. EVO MR's Avatar
boost leak
Old Jun 10, 2010 | 10:02 AM
Carter19's Avatar
Originally Posted by MR. EVO MR
boost leak
I have a tester, ill test it tonight but it don't act like a boost leak idk any thing els that could be wrong? Like did I screw up my maps in the ecu or somthing.
Old Jun 10, 2010 | 10:34 PM
Carter19's Avatar
i mite have figured it out. i read about on the stock vacume lines running to the wastgate an turbo have pills in them to restrict the flow or somthing. im still running with the vacume lines that came with MBC, im going to try to find the stock vacume lines in the morning an try it see what happends. ill keep people posted
Old Jun 16, 2010 | 07:36 AM
Carter19's Avatar
ok so i bought and installed the turbosmart boost controller and have had no problems since. I guess ya get what ya pay for.
Old Jun 17, 2010 | 08:50 AM
DarksideZ's Avatar
Always the case, turbosmarts work great.
Old Jun 24, 2010 | 05:22 PM
SuzukiDan7's Avatar
Before i read your post, I was thinking RESTRICTOR PILLS!! haha.. I did the same mistake on my WRX. The restrictor pill is NEEDED for the ecu to manage your boost levels via wastegate actuator and wastegate actuator solenoid. In lamens terms, if you remove the pills the wastegate actuator will open too early the turbo wont build as much boost.
If you dont mind my asking, how did the car run when this happened? did it just act down on power on top end? Did it backfire at all? Im dealing with a car that someone just ripped the MBC out of and never replaced the WG actuator solenoid.. it runs like ****.
ZanarkO
10
Nov 11, 2015 12:20 AM
RalliMark
Jan 3, 2011 10:27 AM
EvoDan2004
12
Sep 17, 2006 01:23 PM
gsrmin
Northwest Region
Mar 15, 2006 11:45 AM
use2vtec
Jan 2, 2005 12:53 PM
