Northwest Region Includes AK, ID, WY, SD, MT, ND, CO.
need help fast
Old Mar 15, 2006 | 11:16 AM
gsrmin's Avatar
need help fast
stock boost line? anyone have it ??
the vacume hose that you take out when you install mbc??
I need them right away..
thanx
Min
Old Mar 15, 2006 | 11:38 AM
JeffR116's Avatar
thanx
Min
What's the rush? What do you need it for?
You can run to Schucks and pick up some 5/32 vacuum tubing, some clamps and a t- connector. Use some white-out or white marker on one length of the tubing and make your own. It won't have the restrictor pill in it but it will fool the dealer if that's what you're interested in.
Old Mar 15, 2006 | 11:42 AM
gsrmin's Avatar
nm found it thanx^^
Old Mar 15, 2006 | 11:45 AM
jj_008's Avatar
thanx
Min
I think I have an extra set. I will have to check at home. The dealer can get you a set also, if they are not on back order.
The car needs the factory hoses w/ restrictors or you won't be able to boost over 11psi.
bryonboals
Jul 30, 2016 01:42 PM
rhd-jon
Nov 6, 2014 02:10 PM
kmaqueira1
Dec 18, 2013 03:43 AM
omniprobe
AEM EMS
Oct 29, 2008 02:04 PM
CromeOz
Lancer Engine Tech
Sep 25, 2003 06:35 AM
