rear o2 sensor?
Old Jul 2, 2010 | 09:18 AM
adammartini's Avatar
rear o2 sensor?
so i put a full exh on my car when i did i just removed the rear o2 sensor and bolted up the hole. not to long after that my car started runin a bit rougher. i read somewhere before i took it out that it was just used to prevent the P0141 code, is this true? would the rear o2 sensor have anything to do with A/F or anyting that would cause my car not to be runnin the best? should i put it back in?
Old Jul 2, 2010 | 10:01 AM
turbolarry's Avatar
Put it in and run a "CEL eliminator" (a drilled sparkplug spacer). If that doesn't help then you gotta start tracking down the problem.
Old Jul 2, 2010 | 11:38 AM
^ doesent that just turn off the check engine light?
Old Jul 2, 2010 | 11:47 AM
wazzelby's Avatar
If you just removed the rear O2 then your car isn't getting the signal difference between the front O2 and the rear O2 that it needs and will put your car in "limp mode". By using the CEL eliminator you still get a signal from the rear O2 but it's not seeing as high of a gas reading as if it were in the direct stream so it "thinks" the cat is still working correctly and doesn't throw a code resulting in the "limp" mode.
Make sense?
WRECKLESS96
Sep 5, 2009 09:50 PM
vxevolutionxv
Sep 2, 2008 05:14 PM
evane
Aug 21, 2008 02:32 PM
shunderwunder
Nov 30, 2007 04:11 PM
SwiftEVO
10
Jun 7, 2007 04:47 PM
