Is it ok to extend o2 sensor wires?
Old Jun 7, 2007 | 11:55 AM
SwiftEVO's Avatar
I have the innovate xd16 with lc1. I want to keep the lc1 inside of my car. is ok to extend the wires from the o2 sensor? I called innovate and they said not to because the sensor will pick up too much engine noise. How would it do that? Its just a o2 sensor not a knock sensor.
I just want to make sure before I cut the wires.
--Josh
Old Jun 7, 2007 | 11:57 AM
moreryce's Avatar
i extended mine about an extra foot with some solid speaker wire and i had absolutely no problems.. ive had it like that for almost a year now and got it tuned and everything..
Old Jun 7, 2007 | 12:00 PM
hellcat's Avatar
Use shielded cable and you should be fine. Find some that looks like it is made like the wire that comes with the wideband. I seriously doubt you will pick up enough "noise" to throw the wideband off enough to worry about.
SwiftEVO's Avatar
What if I extended it longer say 4 foot?
--Josh
Old Jun 7, 2007 | 12:14 PM
l2r99gst's Avatar
Why do you have to extend the wires, anyway? I have an LC-1, SSi4, TWO xd-16s and everything went in fine without needing any extra length. Where are you trying to route the wires that you need more length?
Old Jun 7, 2007 | 12:47 PM
SwiftEVO's Avatar
Im running it through the hole by the center console on the passenger side. But im running the o2 in the front sensor spot. So im running it over the top of the valve cover like the stock sensor does.
--Josh
Old Jun 7, 2007 | 12:50 PM
Thegame's Avatar
As long as you use the same gauge or larger wire and make clean splices or crimps, you're okay to do whatever you want. It's only an O2 Sensor.
Old Jun 7, 2007 | 01:31 PM
SwiftEVO's Avatar
Im going to solder and heat shrink all of it.
Old Jun 7, 2007 | 02:11 PM
l2r99gst's Avatar
--Josh
Why don't you save yourself some trouble and just get a bung welded on your downpipe right by the grommet. Any exhaust shop will do it for about $20 or less.
Old Jun 7, 2007 | 02:26 PM
SwiftEVO's Avatar
I have one right by it. That where i have been running it. but the response is slow. So i want to move it to the front spot. I have aem so im not running any other sensors.
--Josh
Old Jun 7, 2007 | 04:47 PM
VRSF Tiago's Avatar
Moving the O2 sensor a couple feet is no big deal, just absolutely make sure you are using the same gauge wiring otherwise there will be a different amount of resistance and the signal will be innacurate.
michiganevox
Mar 5, 2011 07:25 PM
veszett
Apr 10, 2010 04:54 AM
Jonas
Lancer Engine Management / Tuning Forums
12
Apr 15, 2009 04:17 PM
sykou
Lancer Troubleshooting
24
Jun 12, 2006 04:53 PM
maxum17ft
Lancer Engine Tech
11
Aug 11, 2005 02:50 PM
