greddy profec b spec ii HELP
Old Aug 18, 2010 | 07:12 PM
SiLLyEVO's Avatar
hellooooooo, well i have a 03 evo, with a 2.3l, a gt35r and i just bought a greddy profec b spec ii. I have NO idea how to set it to the amount of boost i want. i want about 26 psi (((which is what i was running before on my mbc))) can you guys tell me what set-set gain- gain etc, i should run.....
Old Aug 18, 2010 | 07:26 PM
Fast_Freddie's Avatar
Veteran: Navy
set (initial setting) should be around 55
set gain (second setting) I have set at the lowest which is 5
gain (third setting) I have set to 170 (17 psi)
It makes it easier if you set it up for PSI if that is what you are used to seeing.
Old Aug 18, 2010 | 08:54 PM
SiLLyEVO's Avatar
i set it very conservatively and its still boostin out the ***, i dont know why, i double checked i pugged all vacuums correctly and everythings wired up right. its like i cant controll it
Old Aug 18, 2010 | 09:01 PM
mt057's Avatar
The primary boost will be set by turning the knob on the left clockwise or counter clockwise. This intial setting will set the boost. start out around 30% and move up from there. I have mine set at 72% but am shooting for 30 psi or so. Start low and move up from there.
Old Aug 18, 2010 | 09:38 PM
SiLLyEVO's Avatar
mine is set at 30% and still it over boosts, i still didnt take out the extra plug on the soledoin, could that be it?
Old Aug 19, 2010 | 05:32 AM
Veteran: Navy
there should be no "plug" in the solenoid, a filter should be on one, or just vta...
Old Aug 19, 2010 | 08:23 AM
SiLLyEVO's Avatar
Vta?
Old Aug 19, 2010 | 09:36 AM
adcgn45's Avatar
set your boost to 85
set gain at 8%
and start boost at 90
ive had one of these in my car running 24 lbs for a year.
h4ckluserr
Sep 7, 2011 12:09 PM
Shy
Apr 10, 2010 07:57 PM
21Evo-lution
19
Feb 20, 2010 07:55 PM
Inprogress
34
Jun 10, 2008 06:47 AM
J8dailo
May 30, 2007 05:49 PM
