EManage pressure sensor & harness
Old Nov 26, 2003 | 12:23 PM
3deep's Avatar
What does the pressure sensor and harness provide.Does it allow you to eliminate the MAF or give you additional flow metering.
Old Nov 26, 2003 | 02:06 PM
Boeturbolancer's Avatar
allows you to accuratekly read boost/vacuum. Stock sensor doesn't see boost above about 1psi. Thus with this it will see the boost up to what ever sensor it is.
Old Nov 27, 2003 | 07:09 AM
Guru's Avatar
It does not allow you to remove the karman Vortex (EVO's don't have MAF's). To do that you would need either a Power FC D-Jetro model or the AEM. The boost pressure sensor allows you to tune for boost instead of KV sensor frequency. It really doesn't matter that much and in fact I prefer to tune for KV frequency which is the massof air gong into the motor. It is very useful though on cars that are not originally boosted and are now running boost since you can program teh E-Manage to take out timing and ad fuel ONLY when seeing boost pressure and of course map it out according to how much boost pressure it is seeing.
yitzac1990
Lancer Engine Management / Tuning Forums
12
Apr 9, 2019 10:19 PM
rstchris
Nov 17, 2013 05:14 PM
travail
Jan 3, 2011 07:25 PM
4ringturncoat
Nov 14, 2006 08:00 PM
jdm4g63tgalant
17
Apr 25, 2005 05:19 PM
