A/F Question
Old Mar 10, 2011 | 11:25 AM
BEISSEN's Avatar
A/F Question
I have my car tuned with the mods in my Sig and my A/F is bothering me. I see a 11.x dip when getting into full boost but go's to 12.2-12.7 from my view and wanted to know if this is ok or what I should do.
Old Mar 10, 2011 | 11:37 AM
milford's Avatar
yea uhhh might want to add what fuel your on.
Old Mar 10, 2011 | 11:40 AM
milford's Avatar
either way 12.7 up top is WAY to lean for 93. and even tho you could probably get away with being that lean up top on ethanol..its pointless as people don't usually see any significant gains by going leaner then 12.0.
Old Mar 10, 2011 | 11:41 AM
BEISSEN's Avatar
93oct
Old Mar 10, 2011 | 12:10 PM
raasfaas's Avatar
Are you running a meth kit or something? maybe your nozzle is blocked up or the pump has stopped firing.
What afr were you tuned at originally? could be your fuel pump on the way out.
Old Mar 10, 2011 | 12:16 PM
Broham's Avatar
hey beissen, contact tscompusa. let him tune your car man. he'll get you squared away.
Old Mar 10, 2011 | 01:12 PM
Mauricio Evo IV's Avatar
Maybe the fuel pump!!! I has the same problem but changing the pump to a walbro the problem´s gone.
Old Mar 10, 2011 | 07:18 PM
milford's Avatar
well take your wide band and plug it into a computer and find those load cells and adjust the fuel accordingly.. your running 93 so you need to rich it up out the top where your getting those 12s. done
Old Mar 10, 2011 | 09:16 PM
BEISSEN's Avatar
I can use.tscomps tune it would need to be drove and tweaked as im.speed.density he knows his stuff but the other issue is I don't have what is needed like a tactix cable and other stuff. I wont waste my money either as I don't know how to use it.
Old Mar 10, 2011 | 11:10 PM
evilempire76's Avatar
If you have a wideband, your already half way there in regards to the "stuff" you need to tune. You spent all that money modding, whats a few more $100 to buy what is needed to keep it running correctly? Keep an eye on the classifieds and pick on up used. Tom (TScomp) will walk you through everything step by step.
Old Mar 10, 2011 | 11:14 PM
BEISSEN's Avatar
I know tscomp would help but im just not comfortable in touching the ecu on my own. Im talking with spec ops right now and going to try to sell 2 items in my sig to get the tune money and a new manifold as mine is more then I need for my plans.
Old Mar 11, 2011 | 09:14 AM
EVO(boss)'s Avatar
you need to retune your car ,,, or check your fuel pump first ..
Old Mar 12, 2011 | 03:19 AM
BEISSEN's Avatar
You need to get my o2 houseing I fixed and tapped the bolt out since we last talked.
What the heck are you talking about? There is no way to plug a Uego into a laptop or pc of any nature.
I hate you for making me think of this and doing it evoscan and tactrix 1.3u cable is on the way and im having tscomp build a map with Tephra v7. I sold my manifold last night and now need to sell the ebc and im good.
Old Mar 12, 2011 | 05:30 AM
Broham's Avatar
I got an 02 for cheap. Also, fast Freddie makes adapter for uego so laptop reads. You did all the work yourself, you can tune too man with the help of email tuning
Old Mar 12, 2011 | 06:26 AM
BEISSEN's Avatar
Oh ok,
Sorry milford I did not know there was a adapter now.
