3 Bar Map Install
3 Bar Map Install
Just purchased a 3 bar map sensor and tried to install today
. Thought it was simple unbolt, unplug, plug and bolt back in and then start the car (or so I was told). Pretty new at this
. But I did all that and attempted to start the cry and it turned on then shut right off, as if the battery was dead. Tried to start it one more time and same thing happened. Put the stock 1 bar map sensor on and it started. Did I miss something?
I tried searching for the answer but kept getting hits on people selling 3 bar map sensors.
Cheers,
Chug
Cheers,
Chug
bit more complicated than plug and play
https://www.evolutionm.net/forums/ec...tructions.html
that should cover it, let me know if you need help
ninekrevs
Mar 8, 2011 04:27 PM
GGP Wolf
Dec 12, 2007 02:43 PM
