Speed density vs maf
Old Jul 1, 2011 | 06:58 AM
Kevin Knight's Avatar
I know this has been covered but I still font understand why someone would run sd over maf. Other then the vented bov. Please any information would be helpful
Old Jul 1, 2011 | 07:00 AM
Iowa999's Avatar
other reasons off top of head:
MAF is an intake restriction
MAF has a maximum measurable airflow
MAF provides a reading of the airflow that is often several feet back from the injectors
I'm sure that there are others.
Old Jul 1, 2011 | 08:12 AM
Is it harder to tune on? And what's all involved in switching to sd?
Old Jul 1, 2011 | 08:15 AM
binky's Avatar
Another reason is you make more power on SD and boost leaks don't affect a speed density car.
It can be harder to tune if the maps are not setup correctly.
-Bink
Old Jul 1, 2011 | 08:25 AM
Iowa999's Avatar
Sort of. Setting the system up so that you're ready to tune is about two orders of magnitude more complicated. The actual tuning isn't that different at a conceptual level.
Step One: do a ton of reading. This isn't something you learn via some questions on a forum, no matter how good the forum. This is something that you have to truly understand, assuming that you're doing it yourself. We're not talking about plugging in a hand-held or swapping in an EPROM ECU and attaching a laptop. This is closer to (and please don't take this wrong): if you have to ask, then you're not ready.
Old Jul 1, 2011 | 09:42 AM
95630706's Avatar
You have control over load vs. pressure (good or bad)
more freedom with intake plumbing
more freedom with de-EGR'ing and crancase venting
tuning BOV spring rates goes away
idle stabillity
IMHO can be tuned for smoother, less jerkey low speed/ part thottle driving
These are all things I have come to appreciate using V7 SD
Old Jun 17, 2012 | 02:33 PM
EvoIIIAj's Avatar
How easy would it be for me to convert considering I have a JDM Evo VIII that has no map sensor from factory?
Old Jun 22, 2012 | 08:38 AM
Locdizzel's Avatar
Will different altitude atmospheric pressure changed have a big impact on things, because I drive about 80 miles a day to work from high elevation to low elevation
mitdrx
Aug 4, 2018 07:06 AM
Prime12
May 1, 2017 05:55 PM
AWDXTCY
Mar 2, 2016 03:29 PM
KameloT
Mar 29, 2013 04:28 PM
W06EMR
Jan 4, 2011 04:19 PM
