Wideband installed wrong?
Old Aug 3, 2011 | 06:40 AM
bjoseph04's Avatar
Hey guys my wideband was installed by one of my friends the other day and we're not really sure why it's acting up like this. He said he followed the instructions exactly two times.. calling tech tonight after work just wondering if anyone knows off-hand what might be wrong here's a video of me just cruising along. Sorry it's so short I was on my way to the gym and just threw it up real fast.
http://www.youtube.com/watch?v=8-b_aytFkhI
Old Aug 3, 2011 | 06:43 AM
D-VO's Avatar
Whoa! What wideband is this?
Old Aug 3, 2011 | 06:49 AM
bjoseph04's Avatar
Oh sorry mods are 3" exhaust, jmf street intake manifold, act 2900, that's about it.
Old Aug 3, 2011 | 06:50 AM
bjoseph04's Avatar
Oh its an innovate
Old Aug 3, 2011 | 06:51 AM
REV.olution's Avatar
check your 12v line, see if your getting stable power without interference.
Other than that, idk, how far from your turbo is your sensor?
Old Aug 3, 2011 | 07:29 AM
D-VO's Avatar
Did you call innovate yet? I mean the install is pretty straight forward. There may be something wrong with their device. Unless the signal line is cut somewhere and grounding out.
Old Aug 3, 2011 | 07:44 AM
omar123's Avatar
hope the sensor is installed at the right distance ,and check your pos and neg install
Old Aug 3, 2011 | 09:27 AM
304MR's Avatar
did you do the free air callibration? Also make sure you ground to battery to prevent interferance.
Old Aug 3, 2011 | 01:43 PM
bjoseph04's Avatar
I havent done anything I didn't even install it. I don't know what or how to calibrate it. I'm going to try changing the power sources tonight
Old Aug 3, 2011 | 02:22 PM
D-VO's Avatar
Free air calibration is only for the non-install innovates. Did you call them? They may have the best answer for you.
Old Aug 3, 2011 | 06:29 PM
vortico's Avatar
That looks like their new one MTX-L their manual is here http://www.innovatemotorsports.com/s...Manual_1.1.pdf I would check to make sure you did the heater sensor calibration and the free air calibration as those are required (pretty easy to do too). Where did you place the sensor? Is it upstream (towards the turbo) from the cat or downstream. I've heard you get very erroneous readings if you are downstream from a cat. They recommend putting the bung near the end of the downpipe as far away from the turbo as possible. Putting it too close to the turbo also seems to have wierd issues due to the pressure/temperature of the gasses as soon as they exit the turbo.
Old Aug 10, 2011 | 05:27 AM
oldoevo's Avatar
Yes I have putted the O2 sensor(AEM) at the end of the downpipe and it work very good,where is fitted your sensor?
Old Aug 10, 2011 | 06:59 AM
vortico's Avatar
My sensor is about 2 inches from the end of the downpipe near the cat, at around the 2:30 position (passenger side of downpipe a couple of degrees up from horizontal). Works pretty well although I think I have a minor leak when idling as the AFR goes a bit crazy then, but only then heh.
chuggychug
Jun 25, 2011 07:46 AM
DJmarkymark
19
Sep 11, 2009 07:05 PM
destro92179
Sep 9, 2008 08:03 PM
Chabada15
Jul 22, 2008 08:42 AM
QwikEVO
Jul 2, 2006 02:35 AM
