Fan relay issue and Aem Ems - Evo 8
Does anyone else running an EMS have issues with fan relay chattering? I looked at the manual to see where the fan relay is hooked up to on the EMS. The pin out says it is a PWM pinout. I guess the Pulse width frequency is too low or something because I do not know why the relay chatters.
Can anyone give me some insight as to fix.
not sure if this has anything to do with it but i remember their being a recall on the fan controller.... yup just found my carfax it shows there was a recall on 6/27/08. not sure if this has anything to do with that tho
how do i check for fan module. my relay be clicking non stop and the fan struggles to turn on. but when i turn on the a/c the relay stops clicking and the fan is running fine. i have changed that relay abt 4 times already it burns out after couple of months. i need to take car of this problem before it catches fire. sooo some one plz help me
my fuse box only has 2 relay...is it suppose to have 4??
well i ordered a module yesterday and it shud be coming in today i will change it and let u guys know if it fixes the problem
update on my situation i just got this problem solved. if any one is having this problem after running a EMS u need to change ur setting in ur EMS for A/C and fan settings. or u can take it to ur tuner and have him do that for you.
i realli dont know cuz i had someone do it for me... but here is a link that may help u out....
http://forum.aempower.com/forum/inde...;topic=26092.0
but that problem is onli cuz of the setting of the ems...... my car is running like a charm...
I thought I better contribute to the community. Anyways got my relay clicking issue solved as well. So that all knows the PNP setting on the base map works fine. Make sure the base setting are the same as the startup map for your box. Do a software compare to make sure the ac controls are the same under "setup" and also check the "options" under outputs.
In my case the guy who own the car before me adjusted the ac settings off the base but didn't really know what he was doing
Basically the aem is confusing if you are triggering the relay to come on via the ac controll setting you do not want to go to options and tell it to turn on there as well. This will confuse the aem box and cause the relay to chatter like we are seeing. You will notice idle 5/6 is the output used for fan and LS11 is used for ac clutch (1313 box). You will notice both those output on the base map under "options" to be not checked as active. The reason is you don't want two places in the software tuning on the relay. Hope this helps all...
.Basically the aem is confusing if you are triggering the relay to come on via the ac controll setting you do not want to go to options and tell it to turn on there as well. This will confuse the aem box and cause the relay to chatter like we are seeing. You will notice idle 5/6 is the output used for fan and LS11 is used for ac clutch (1313 box). You will notice both those output on the base map under "options" to be not checked as active. The reason is you don't want two places in the software tuning on the relay. Hope this helps all...
Raceghost
15
Dec 1, 2019 06:34 PM
Cj.lara920
Mar 9, 2011 11:55 PM
