Engine knock
Old Nov 29, 2011 | 05:32 PM
Heezayx's Avatar
Engine knock
Hey guys.... my check engine light flashes fast when i hit boost and ive been getting alot of feedback saying its "knock"
can someone tell me exactly what knock is?
Old Nov 29, 2011 | 05:34 PM
prowakeskater's Avatar
detonation which could lead to a window in your block. Pull boost with your MBC, your car is telling you to stop killing it
Old Nov 29, 2011 | 05:41 PM
Heezayx's Avatar
im 95% sure i have a boost leak somewhere because i hear it and feel it
could that be triggering the CEL?
Old Nov 29, 2011 | 05:50 PM
Spec-Ops1's Avatar
A boost leak can cause knock yes...
Old Nov 30, 2011 | 07:39 AM
BillSpec's Avatar
Has the car been tuned? If its knocking and has tephra patch then the cel will flash
Old Nov 30, 2011 | 10:04 PM
Heezayx's Avatar
yes i bought the car tuned.....
tuned by akuma motorsports im going to call them and ask about it
Old Dec 5, 2011 | 12:27 AM
Fastone_evo6's Avatar
turn down the boost ,
Old Dec 12, 2011 | 06:07 AM
ca18hatch24's Avatar
You are likely running too much boost. Turn down your MBC, or check for any loose vacuum lines, as you may have a boost leak causing the wastegate to not function properly.
jameswwt
14
Jan 8, 2012 05:12 PM
jjayp
Mar 12, 2011 12:01 AM
rs03evo
Sep 11, 2010 06:37 PM
Derek888
Oct 22, 2005 06:50 PM
EVIL_EV0
Aug 12, 2005 08:06 PM
