DSMlink
Old Apr 10, 2012 | 04:14 PM
RBehne2's Avatar
You don't need a patch harness. You will have to CUT (with room to splice) and de-pin the Fuel Temp wire at pin 77 on the factory Evo ecu plug, since the 2G ecu does not use this. Then insert that de-pinned wire into the Evo's empty pin #56, and extend the wire to the number 1 pin at the Data Link Connector.
If this is not done, Your computer will have a fit while Data Logging. All the other converted and switched wires are already done to the ecu internally when you install it.
Old Apr 11, 2012 | 05:06 AM
ToFastforU_99's Avatar
You could not just run a jumper harness inside the 2g ecu like what is done already?
NVM Found this out.
http://www.ecmtuning.com/wiki/2ginevo8
Cyborg-x
Dec 31, 2016 04:48 PM
Dennis F
For Sale - Cars For Sale
Aug 7, 2016 06:29 PM
92 GSR-4
May 9, 2014 10:08 AM
turbotaloon95
19
Jul 22, 2013 03:15 AM
keeler
Dec 8, 2008 06:47 PM
