Evo4 misfire!
Old Mar 14, 2012 | 12:25 PM
Moodyevo4's Avatar
Evo4 misfire!
Hi could anyone help I have an evo4 which has recently
Developed a misfire just as the turbo kicks in and only once
It has warmed up I have replaced the plugs already any ideas?
Thanks
Old Apr 6, 2012 | 08:17 PM
pangyau's Avatar
Hi guys,
Same thing happened to my ride E8MR(JDM - Stock)
All hoses checked, UICP & plugs has been changed.
Throttle body & Air Flow sensor cleaned.
Especially during over taking at 4th or 5th gear.
Kinda miss-fire for the few second then able to boost.
Please advice...
Old Apr 20, 2012 | 10:35 AM
ben-_'s Avatar
have you tried looking at your coils? and also are the plugs spark gap correct? you should start with the simple stuff before going on to hader things. goo luck man.
Old Apr 22, 2012 | 12:05 AM
pangyau's Avatar
ben,
Thanks for the advice.
My bet also the Coil... Probably end of this month going to change.
I've read about Coil-On-Plug(COP) without CDI by several brand.
Could you suggest me which is better?
I don't have opportunity to test/swap other coil by other Evo user.
Maybe need to buy new unit....
Old Apr 22, 2012 | 05:48 AM
ben-_'s Avatar
ya, a simple test you can do to see if it is a coils is to switch your coils in your engine and see if the misfire travels, so like if its cylinder 4, swap that coil with cylinder 3, and see if the misfire travels to cylinder 3. its a simple test and most likely going to 100% tell you if it is a coil. first i would go and see how much a oem coil would cost, because its made from the factory with it, its going to work with the car no matter what, off the top of my head i'm not sure on a aftermarket coil, i have not swap my oem coil to aftermarket, so i dont know the best brand on that, but oem is sometimes the best way to go.
johnashton11
11
Sep 13, 2019 01:23 PM
2006GSR
Aug 20, 2016 09:22 PM
commbubba19
18
May 5, 2016 08:32 AM
bjstrick
13
Jul 11, 2012 05:14 AM
moss99
Feb 19, 2011 07:47 AM
