AccessTuner & uego data log???
Old May 7, 2012 | 10:52 PM
LAN_EVO's Avatar
Howdy all, I know almost everyone says accessport is dead but I had one and
decided to slowly learn how to tune my own car with the AccessTuner program. Now
my only question is on the program it states that you CAN data log using an aem
uego wideband but I just cant seem to figure out how to make that work. The
wideband works perfect it's just that when I connect the laptop to the ecu and try to
data log afr it says there is nothing attached. I know it has something to do with the
blue and white wires on the wideband but I myself have no idea where or what to
connect them to in order to make this work. Thanks!
Old May 8, 2012 | 01:47 AM
LAN_EVO's Avatar
I guess what im trying to ask is if the only way to log with a wideband while also
using the cobb accessport, is to go out and buy a RS-232 (DB-9) and splice the blue
wire from the wideband into pin #2 and have the laptop connected to both the
wideband and ecu. I'm leaning into the assumption that IF I could find the serial pin
from the ap connector couldn't I just splice into that pin and just have the laptop
connected to the ecu???
Old Jun 2, 2012 | 06:03 PM
LAN_EVO's Avatar
bumpty, does anyone even use the ATR program???
Old Jun 29, 2012 | 03:39 PM
redcivic's Avatar
Not sure on ATR for the EVO is different or not but for the RX-8, ATR can log from an additional wide band but it only supports the wide bands from Innovate and PLX. I have a PLX mulitgauge AFR.
Old Mar 23, 2013 | 07:55 AM
lando524g's Avatar
Reviving an old one... But I'm in the same boat, as I am trying to learn to tune as well. Found this page on Cobb forum.
https://cobbtuning.zendesk.com/attac...ware+v1.00.pdf
I still need to order the serial to usb converter because all the electronic stores want 40-50 bucks for one.
mrfred
Sep 14, 2022 07:08 PM
discodino
Feb 22, 2017 03:01 PM
JakeSoberman
Nov 30, 2015 11:28 AM
erikm-x
Apr 20, 2014 12:29 AM
COBB Tuning
33
Jul 21, 2011 09:33 PM
