How to track the cells being used with evoscan
Judging from your screenshot, it would appear that the definition for your ROM is pooched. I had that happen to me a while back. I copied the EVO7base.xml definition (the one I needed) from ECUFlash into the proper EvoScan folder, and now my table axis are good again. I can load any of my old logs and follow the load cell traces.
Why are you running that rom? The 94170715 is the one I use for my Evo 8.
I did change a few of the values In the timing table to give the load a wider range. Could that have effected anything?
Because that is the ROM for the 2005 USDM Evo 8 as opposed to yours which appears to be a Tephra V7 ROM. If anything I could swap to the 96530006, which is the EDM for an '05. I'll be honest I'm new to this while ROM/definition/XML stuff. It's a bit of a blur.
Did not mean any offense just curious. I guess that I had not seen that stock 05 map put up before. Was curious if it was some aus rom or something.
I tired the EDM "universal" 9653 but I found to like the 94170015 more, even over the stock rom 9417008 that my car came with. Then switching over to Tephra V7 from Tephra V5 was a big improvement. Love me some Big Maps.
I am sure that you have already seen it but this page was helpful to me...http://evoecu.logic.net/wiki/Downloads
You can use a 9417 ROM on an 05 EVO. It works great. I personally dont like the 9653 ROM.
Here it is in ECU flash: (Columns are normal)
And here it is in EvoScan Map Tracer: (Columns are jacked up)
This is the same exact ROM file on both applicaions and the one that is currently in my car. How do I made the columns line up correctly on Map Tracer? If this was your car what would you try first? (But I need step by step becuase I'm a noob at this)
I'd trust this response. From my little knowledge the XML files are looking in the wrong place in the rom for the scaling information which is why it is all jacked up.
I will give this a try. Vortico is going to help me with it on Sunday after AutoX as he is a computer genius and I am not so much! I will post back up and let you know if it solves it or not.
I swapped to 94170015 ROM and copied all of my tables over to it and then it wouldn't start. I had the immobilizer code in there and it was cranking over, just wasn't firing up. I flashed back to my old ROM and it started right up. Any ideas?
Another thing that happened to me was the valle mode was automatically put on for some reason. You might double check that it is disabled.
Does the cel blink when you put the key to on? If so the Valle mode is on.
Did you use the imobilizer that it originally had or the one you put on there?
You need the correct immobilizer hex. Its different from the immobilizer and corresponds to the year of the car. 9417 is originally an '03 ROM.
For an 05 car, the immobilizer hex is 0x0058.
If you need any help converting over, just let me know. Hit me up on AIM.
I read this thread: https://www.evolutionm.net/forums/ec...6940011-a.html, and they expirienced the same thing I did and it seems like the big thing is using 96530006. I'm reading this thread now, https://www.evolutionm.net/forums/ec...9694011-a.html, and it's the same thing about swapping from 96940011 to 96530006. Why did you say that you don't like the 96530006 ROM?
Originally Posted by razorlab
Well I got some bad news for the 05 guys.
Tephra sent me a 94170014 v5 rom to try and flash into my 05 Ecu.
It flashes fine. Just the car won't start afterwards.
Even tried some non V5 mod 94170014 and 94170015 with no luck.
Doh.
Doh.
