Timing Tool
Old Aug 22, 2012 | 05:25 PM
bryonboals's Avatar
Timing Tool
This is first time doing timing belt for Evo, but done timing belt on other cars. I bought a bunch of tools one tool is so I do not make the belt too tight. Can anyone tell me how it works. here is some pics of it any info will help
Old Aug 22, 2012 | 09:18 PM
07EvoIX's Avatar
Allows for easy adjustment of the camshaft spur belts having idler pulleys with pin holes. Protruding pins grip the centre of the idler pulley and rotate it around its off-center retaining bolt. This rotation then allows for camshaft spur belt tension adjustment.
cheers
Old Sep 1, 2012 | 02:44 PM
Graphic's Avatar
Get a 1/4 inch lb torqe wrench. You are missing 2 more special tools. One holds the crank shaft, the other is basically a really long bolt that will push down the tensioner.
For a 9 (IX) After you are 100% on timing marks before any rotation you need to do exactly 1/4 turn counter clock wise, then two full clockwise rotations of the crank shaft. You then verify all mechanical timing marks are lined up. There is no need for a timing light. Go get a tractrix cable and get ecu flash, & evo scan.. Read up on how they work. Then you might want to look towards downloading tephra as well.
It is very important to get the correct tension on the balance shaft and timing belt so you don't have a catastrophic failure down the road.
Old Sep 1, 2012 | 02:48 PM
Graphic's Avatar
I would highly suggest doing research on timing belt procedure before you tackle it. It's honestly not that hard like some companies will try to feed you. I believe Evomoto has a good write up, but don't forget about the balance shaft procedure. I believe if you look around, there is a post somewhere, from English Racing that states a if you hold a balance shaft at 12 o'clock and let it go, the balance shaft will drop in a specific direction so you know the exact way it's facing. FYI ER will do T-belts for $500..
bryonboals
Jun 27, 2014 02:20 PM
bryonboals
13
Sep 5, 2013 01:04 PM
bryonboals
For Sale - Miscellaneous Automotive
10
Sep 23, 2012 08:58 AM
Gsxfury
For Sale - Cars For Sale
42
Dec 9, 2007 09:09 AM
