LM2 analogue out logging in evoscan
Has anyone sucessfully logged in evoscan or ecuedit, analog 1 input on the LM2 to any logger ??
I have setup a 3 bar map sensor to read in volts on the LM2 through its analog input, now i know LM2 cant be used through usb on evoscan so i was able to make a lead to log wb02 through the MTX out on the LM2 which worked, any way can i do this to display the analog1 voltage in evoscan off the LM2?, then i can calculate a formula to convert to bar
