Noise and Vibration
Old Jan 28, 2013 | 08:46 AM
eking's Avatar
Noise and Vibration
Just had the timeing belt replaced on my 03 EVO IIIV and there is a low humming noise and a slight vibration as the turbo spools. The mechanic sais he mistakenly erased the ECU while doing the work on the car. He claims that the noise and vibration is from the ECU reflash. He says that he did some upgrades to the setup. The car idles fine and runs good, any thoughts?
Old Jan 28, 2013 | 08:50 AM
m32's Avatar
m32
Timing belt is to tight.
Old Jan 28, 2013 | 09:00 AM
eking's Avatar
My first thought was the balancer shaft off a tooth or so, but they claim it's not.
Old Jan 29, 2013 | 10:37 AM
m32's Avatar
m32
If its off a tooth car would run like crap and miss. Humming noise is caused by the timing belt to tight bro, vibrations can be the harmonic balancer.
Old Jan 29, 2013 | 10:56 AM
eking's Avatar
Thanks for the info!!
Old Feb 1, 2013 | 08:27 AM
eking's Avatar
Ok, so if everything is lined correctly except the balancer shaft it will still miss and run rough?
Old Feb 5, 2013 | 08:31 AM
eking's Avatar
Another trip to shop, another wasted day. The shop claims the timing belt is fine, car still vibrates. Time to find someone else to look at it.
Old Feb 5, 2013 | 08:54 AM
Wahtash's Avatar
Whine = balacne belt too tight
Vibration = forward balance shaft 180 degrees out
PaulyX
Jun 26, 2013 01:54 PM
thatguy
13
Sep 14, 2012 04:47 AM
seiya
Lancer Engine Management / Tuning Forums
Jul 26, 2012 09:43 AM
fastsrt4u
Sep 11, 2008 10:08 AM
cetinsaya
May 20, 2007 12:53 PM
