evo 7 ecu tune help
evo 7 ecu tune help
i have a evo7 jdm. i want to tune my ecu with economic type. it means 0-2000rpm low consumption then 2000rpm-7500rpm high performance. is this possible?
and my mod list. airintake ,3"tbe, 20G turbocharger, BC280
what i need some item for tune
Yes you can tune for economy and performance in the same map. The tables are like a 2 axis graph with the horizontal axis being load and the vertical axis being RPM. The intercepting point will be your target AFR or timing advance. I've pasted a link below, have a read, it will tell you much more than I can.
https://www.google.co.nz/url?sa=t&so...vE2S-wTiXAjWtQ
babaz7
Mar 24, 2016 02:09 AM
silverstream
14
Nov 17, 2006 04:19 AM
