Evo IX tuning results
Old May 20, 2013 | 05:25 AM
Ridge727's Avatar
Hello everyone,
Here are the results of my tune on 05/20/2013 in my 2006 Evo IX SE. We couldnt do anymore because we maxed out the factory injectors, but I am very pleased with the results.
(355 whp 347 Ft. Lbs) at 22.4 psi
Mods:
-Injen Air Intake
-Megan o2 Housing
-Megan Turbo Back Exhaust with High Flow Cat
-Perrin Intercooler
-Injen Upper and Lower Intercooler Piping
-Turbo Smart Manual Boost Controller
-Walbro 255 Fuel Pump
Attached Thumbnails Evo IX tuning results-evodyno.jpg   Evo IX tuning results-dyno1.jpg   Evo IX tuning results-dyno3.jpg
Old May 20, 2013 | 05:29 AM
ThatOneKid's Avatar
Nice numbers for those mods. Dynojet I'm assuming?
Old May 20, 2013 | 05:31 AM
drisn's Avatar
Those are nice results, just adding injectors will get you 10-15 more torque/whp
Old May 20, 2013 | 05:36 AM
Ridge727's Avatar
Yes it was a dynojet, and I would go ahead and do the injectors but I'm pretty sure I felt the clutch slip a little on the way into work this morning....and based on what I have already researched thats a pretty penny....
Old May 20, 2013 | 05:54 AM
misterevo8's Avatar
man i cant wait to get to VA and get mine retuned on 93 octane. but after the cams at least. 91 oct in CA sucks.
Old May 20, 2013 | 07:37 AM
PL_MR's Avatar
Nice, I have a setup pretty close to you (I have stock intercooler) and I'm presently in tuning.
Do you think it would be safe for the stock turbo to run 25 psi dropping to 21psi at 7000rpm?
My injector are max out to, IDC is about 110-115% at high rpm but from what I have read, it's seem to be ok for the injectors if you are not keeping your rpm for too long like a dry lake racer...
Old May 20, 2013 | 07:42 AM
Ridge727's Avatar
Evo 9 turbos can support 25 psi reliably, but like i said earlier in one of my posts i was limited by my injectors....so as long as you got a fuel pump and injectors....you might be able to hit that 25 psi. But I would focus more on a HP goal more than a psi rating, there are many factors that affect your end result and 25 psi might not even be necessary.
dont push them too much...a failed injector under high load would be no good... My goal was a tune for longevity and reliability, but this car is also my daily driver.
And i feel for you in CA having to use that garbage 91....
Old May 20, 2013 | 07:59 AM
PL_MR's Avatar
I lucky for the fuel, in Montreal, we got petro canada offering 94.
Do you know what IDC you were running?
Old May 20, 2013 | 10:59 AM
Ridge727's Avatar
I'm assuming you are referring to "Injector Duty Cycle." and I am not sure I will see if I can get ahold of the guy who tuned my car and have him look it up.
Pardon my delay in response...It took me a while to figure out the "IDC" haha I havent seen that before.
Old May 20, 2013 | 12:31 PM
Boosted Tuning's Avatar
Thats not a dynojet dyno. Its called a DynoCom dyno. Reads about the same as a dynojet, when its on 1.0CF.
Old May 20, 2013 | 01:03 PM
Ridge727's Avatar
Good call......you are correct!
either way my car is running great, any recommendations on which clutch i should get to support this tune with my mods?
Old May 23, 2013 | 03:36 PM
PL_MR's Avatar
Well If you feel your clutch is starting to slip or you are always dumping the clutch in 1st gear at 7000 rpm, it may be necessary but from what I have seen about other guy on the forum, some had done over 500 drag run in the 11sec on stock clutch and it still good...
But I think there has been a forum just for about what clutch people like, you could try to find it.
Old May 24, 2013 | 04:46 AM
Ridge727's Avatar
So far I have been unable to get the clutch to slip, so no worries until I feel it occuring on a regular basis...Thanks for the feedback.
Old Jun 3, 2013 | 04:50 AM
misterchonger's Avatar
Hello everyone,
Mods:
-Injen Air Intake
-Megan o2 Housing
-Perrin Intercooler
Where at did you get this tune done?
Old Jun 6, 2013 | 03:10 AM
soderdna's Avatar
I'm in the London area looking for a tuner too
