evo 9 switchable anti lag
Old Jun 13, 2013 | 03:37 AM
BhpTuner's Avatar
Hi, could someone tell what's required to add switchable anti lag on an evo 9?
Old Jun 14, 2013 | 07:57 PM
ProPilot04's Avatar
Hi BHP.
There's no such thing as a switchable ALS truly.
I should preface that with stating that many people confuse the Evo's factory launch control or no lift to shift (NLTS) systems with an antilag system. Those actually aren't ALS at all though.
If you're looking for a TRUE ALS, then you'll have to make semi permanent changes to your vehicle. Depending on the system you choose, you'll need a full standalone ECU that supports it, and a manifold that has the plumbing for it. Regarding the "switchability" that can be done with the tune and the ECU.
Old Jun 22, 2013 | 01:32 PM
211Ratsbud's Avatar
You're looking for pops and bangs with the sas hardware. MLR. Aka lancerregister.com is the spot for that.
U just need an alt map switch and some tuning.
Old Jun 29, 2013 | 02:47 AM
BhpTuner's Avatar
Ok, thanks guys
Evo5madness
Aug 26, 2013 08:32 AM
EvoTillIDie
Aug 17, 2011 05:34 AM
555R
45
Jan 4, 2011 06:06 AM
Spizz
May 16, 2009 02:43 AM
MRfabolous
102
Feb 18, 2009 02:17 PM
