Evo 8 ECU in Evo 4 Problems
Old Jun 29, 2013 | 05:29 PM
Dvolution's Avatar
I will soon be swapping an Evo 8 engine into my Evo 4. I received my Evo 8 ECU today and thought it would be a good idea to get the immobilizer problem out of the way before the swap. I plugged in the E8 ECU with a conversion harness and a few weird things happened:
ECUFlash read the ROM with but told me it was an unknown one.
After making sure I had the proper drivers and still no luck reading the ROM, I decided to try turning the key, why not? The car started without any immobilizer periphery modifications!
The car idled fine but stumbled alot when the throttle was pressed, even lightly. (I have Evo 6 injectors)
Any ideas as to why I can't read the ROM, or why it started without ECU mods?
Old Jun 30, 2013 | 11:30 AM
todd6027's Avatar
attach the rom
Old Jun 30, 2013 | 11:42 AM
Dvolution's Avatar
Sorry, I should have done that in the first place.
File Type: bin
Old Jul 1, 2013 | 12:34 PM
todd6027's Avatar
immobiliser is off in that rom , what wires are swapped in the harness ???
you need to turn off front o2 heater circuit evo4 hasnt a heater circuit periphery 0 bit 14
its 96530706 rom.
disconnect pin 6 sas evo 4 - egr evo8
remove pin 91 and ground the wire
Old Jul 1, 2013 | 02:38 PM
Dvolution's Avatar
Thankyou very much todd6027, I can read the bin file now!
Pin 8 and 22 are swapped
Pin 6 and 87 are disconnected.
Pin 91 is wired to chassis ground.
I think I wired up the A/C fans wrong. Your post from a few years ago regarding this swap said to move Pin 20 to 32 and move Pin 21 to 34. 20 to 32 makes sense but shouldn't Pin 21 be moved to Pin 31 as the E8 doesn't use Pin 34?
I am now trying to figure out why I'm running like crap. Could someone please have a look at my map?
File Type: bin
Old Jul 2, 2013 | 02:36 AM
todd6027's Avatar
i think so , the pinout i used originally was incorrect , i e mailed you a rom to try with stock 560cc scaling and latency original was set up for bigger injectors
Old Dec 20, 2013 | 10:55 AM
jarg's Avatar
Hey guys, sorry to bring this up from a few months.
I will do the swap from evo8 ecu to my evo4, now reading some older post this is what i found, and before a start i will like to see if is correct:
swap
pin 8 and 22
move pin 20 to 32
move pin 21 to 34
32 /34 have no pins/wires on evo4
remove
pin 87
run extra wire /pin to 79 for flash connector
join wires to hot cat sensor connector under drivers seat or remove bulb in dash
you will need to disable immobiliser in ecu and turn off cel for fr o2 sensor heater circuit or wire in a 4 wire o2 sensor
12 v switched to one o2 heater wire and the other heater wire to pin 60 at ecu
Do i have to add this to the process:
disconnect pin 6 ?
and
Thanks i appreciate all help
Old Dec 20, 2013 | 11:42 AM
jarg's Avatar
I also found this pinout swap, is it correct ?
Attached Thumbnails Evo 8 ECU in Evo 4 Problems-evo-8-ecu-evo-4-wiring-diagram-1-.jpg
Old Dec 20, 2013 | 12:52 PM
todd6027's Avatar
yes looks correct
disconnect pin 6 also
Old Dec 23, 2013 | 03:25 AM
jarg's Avatar
thanks, next weekend i will go for it
nuk1ear
Nov 27, 2016 05:13 PM
SiC
Jan 19, 2016 08:03 AM
secretagentstv
Oct 5, 2014 12:13 PM
smoke3d
May 15, 2014 11:49 AM
wacboyjulian
Apr 7, 2014 11:59 AM
