Tactrix help
Old Aug 25, 2013 | 09:04 AM
volcano's Avatar
Tactrix help
I have a Evo 9 that has developed a periodic, but significant engine hesitation at around 5k rpm under WOT and I am trying to diagnose what may be happening through data logging (the issue did not show up on the dyno).
I just bought a tactrix openport 2.0 with the SD card, but I am not sure as to which software I should download for data logging (I am not reflashing or retuning). The choices appear to be either ecuflash 1.44 or the openport 2.0 driver. I downloaded the openport 2.0 driver software and opened the SD card - the SD card had no files on it.
So, for data logging only, do I use the ecuflash 1.44 software, or do I use the open port 2.0 driver software?
Any help would be appreciated.
Thanks
(Apologies in advance if posted in the wrong spot)
Old Aug 25, 2013 | 11:05 AM
r3dtr1ckz's Avatar
Evoscan is used for data logging.
Old Aug 25, 2013 | 11:18 AM
211Ratsbud's Avatar
Evo scan 2.9 for data logging and I dislike 1.44 ecu flash as the graphing error realy bugs me.
Gl and check out the recompile videos!
Also Mitsu logger check the ecu flash there's guides there.
Old Aug 28, 2013 | 07:06 AM
volcano's Avatar
I made a log of several runs, but I'm not sure how to interpret the data. Anyone out there want to take a look at the files to see if they can spot whats going on?
rich3389
Jul 22, 2014 11:23 AM
bleunetizen
Feb 12, 2013 08:45 PM
RA09
10
Feb 4, 2013 09:19 AM
RS200Z
Jan 12, 2013 06:42 PM
accident
Oct 20, 2009 11:46 AM
