Evolution 6 Gates Blue Timing Belt
Old Jan 9, 2014 | 03:57 AM
99evoVI's Avatar
I have just installed a blue Gates timing belt onto my stock evo 6. It has done 55km on the new belt and it feels like i have a sluggish car/loss of power. Could this be to do with the fact the belt is still wearing in since it's a new tight belt?
Old Jan 16, 2014 | 06:47 AM
S.Brewer's Avatar
FCOTM Winner
Did you set the timing right?
Old Jan 17, 2014 | 07:28 PM
99evoVI's Avatar
Question Rough Idle
Yes, the timing was set correctly but the issue is more so at idle. The car idles and sounds like it has a misfire like a cough every couple of seconds. Im planning to check the plugs, lines and timing belt tension.
Old Mar 2, 2014 | 11:00 PM
99evoVI's Avatar
Problem Solved
The auto-tensioner needs to be put on after the manual tensioner has been tightened. This caused the belt to jump a tooth on the exhaust pulley since as the timing belt wore in, the auto-tensioner couldn't re-tension since the arm was fully extended.
No problems since I re-did the manual tensioner first.
MnchMnchV84Lnch
Jun 22, 2014 10:46 PM
RussellM
MitsubishiParts.net - WA
Apr 1, 2014 10:22 AM
clubEVO93
Jan 8, 2014 08:42 AM
tim85851
11
Dec 10, 2011 09:42 PM
TTP Engineering
17
Jun 27, 2007 01:54 PM
