Load question
Old Apr 24, 2015 | 01:42 PM
usernameinuse's Avatar
Load question
I was doing a log after getting my car back from having the motor built and tuned and the load exceeds max and resets to zero. When it does that it briefly hits the 0-100 range where it has a lean spike in near full boost. Is there a simple way to modify the range of the load or what voltage equates to what load?
Old Apr 25, 2015 | 08:41 PM
blockade35's Avatar
What load value are you looking at? The load typically goes from 0 to 200+ as it is just a somewhat arbitrary value. My max load I hit under WOT is around 240.
Old Jun 7, 2015 | 08:48 AM
Stevo9267's Avatar
Have you changed your MUT table so you can log 2 Byte load?
I think the max with 1 byte is 255 which wouldn't explain why yours is breaking after 100
Here's the how to:
https://www.evolutionm.net/forums/ecuflash/263618-evo8-2-byte-load-how-94170014-rom.html
And here are the values you need if you have a ROM number different than in that link:
https://www.evolutionm.net/forums/ecuflash/327185-official-2-byte-thread.html
Old Jun 7, 2015 | 08:50 AM
Stevo9267's Avatar
Wait I think I misread post the first time. This should increase the range from 0-255 to 0-65535
leecavturbo
Oct 29, 2010 01:55 PM
razorlab
100
Oct 9, 2008 04:44 PM
razorlab
Apr 24, 2008 04:17 PM
bigric09
Sep 4, 2007 09:59 AM
kreionic
Jun 7, 2007 03:13 PM
