Revving itself
Revving itself
Hey guys not sure if posting in the right spot but
My Evo 9 revs itself when cold in the morning from about 1000rpm to about 1.500rpm also struggles to start in the morning but other than that car runs good 286kw atw 25psi
If the symptom manifested right after the tune, then your tuner should be able to fix it.
If you tune it yourself, then more details would be necessary.
Stock ECU reflash / piggyback / standalone?
MAF / SD?
Any log file on cold start and warm up that you can post up?
MAF / SD?
