Evoscan and Windows 10
Old Jul 21, 2015 | 04:57 PM
aamoedo's Avatar
I most certainly do not have my Windows 8 disc. Anyone have any guesses as to whether Evoscan is going to be compatible/willing to take one for the team and update and report back?
Old Jul 21, 2015 | 06:07 PM
Red_06_EvoRS's Avatar
As of July 29th (week from tomorrow), *tons* of Windows 7 & Windows 8 PCs will start the free download of Windows 10. Surely one of those will have EvoScan so if you wait a bit, someone will probably have an answer for you.
Old Jul 21, 2015 | 06:22 PM
hearnoevo's Avatar
windows
Worse case, you can always restore your windows from an ISO image as long as you have a valid license key.
Old Aug 15, 2015 | 11:49 PM
ixbreaker's Avatar
I just tried windows 10 and the 1.44.4501 EcuFlash on one of my newer laptops and got errors. Thought my ecu was bricked because I got the same failure on an earlier map that was successful, which also means the errors are intermittent. I'm not sure what the problem is. Luckily I was able to flash an older map on my old windows 7 netbook with success!
I can't narrow down what the main cause was because I did 2 changes. I had problems with earlier versions of EcuFlash and windows 8 on my new laptop for some reason, which is why I went straight to the latest version.
The 1.44.4501 drivers did fix a lagging / dropout issue I had with logging on Evoscan which is a plus. Please have a look at EcuFlash log.
[20:07:28.216] J2534 API Version: 04.04
[20:07:28.216] J2534 DLL Version: 1.01.4500 Jun 26 2015 15:08:08
[20:07:28.216] Device Firmware Version: 1.15.4474
[20:07:28.216] Device Serial Number: TALaXZTZ
[20:07:31.060] sending init sequence 1 (0001)
[20:07:32.091] got 0x05 response
[20:07:32.091] sending init sequence 2
[20:07:32.091] got 0x1B response
[20:07:32.091] sending init sequence 3
[20:07:32.450] entering bootloader
[20:07:32.450] sending kernel size (0)
[20:07:34.450] sending kernel load address (0xFFFF6000)
[20:07:34.450] uploading kernel
[20:07:34.450] verifying kernel checksum response
[20:07:34.450] kernel valid
[20:07:34.466] sending init sequence 2
[20:07:34.466] got 0x1C response
[20:07:34.466] sending init sequence 3
[20:07:34.825] entering bootloader
[20:07:34.825] kernel read area: addr: 03FFFA len: 0006
[20:07:36.857] kernel rsp page: 030000
[20:07:36.857] kernel read addr: 03FFFA len: 06
[20:07:36.857] kernel rsp end
[20:07:38.904] sending init sequence 1 (0001)
[20:07:39.935] got 0x05 response
[20:07:39.935] sending init sequence 2
[20:07:39.935] got 0x1B response
[20:07:39.935] sending init sequence 3
[20:07:42.279] entering bootloader
[20:07:42.279] sending kernel size (0)
[20:07:44.279] sending kernel load address (0xFFFF6000)
[20:07:44.279] uploading kernel
[20:07:44.279] verifying kernel checksum response
[20:07:44.279] kernel valid
[20:07:44.279] sending init sequence 2
[20:07:44.295] got 0x1C response
[20:07:44.295] sending init sequence 3
[20:07:44.654] entering bootloader
[20:07:46.654] sending kernel size (4524)
[20:07:46.654] sending kernel load address (0xFFFF7000)
[20:07:46.670] uploading kernel
[20:07:47.404] verifying kernel checksum response
[20:07:47.404] kernel valid
[20:07:47.623] kernel get version
[20:07:47.623] kernel version is : OpenECU Mitsubishi SH7055 DUAL Kernel V1.07
[20:07:47.623] reading kernel comm buffer size
[20:07:47.639] comm buffer size set to 512
[20:07:47.639] reading kernel flash buffer size
[20:07:47.639] flash buffer size set to 4096
[20:07:47.639] -- flashing image to ECU memory --
[20:07:48.045] -- comparing ECU flash memory pages to image file --
[20:07:48.045] seg start len ecu CRC32 img CRC32 same?
[20:07:48.061] FB01 00000000 00001000 3D4B5865 3D4B5865 YES
[20:07:48.076] FB02 00001000 00001000 1CF17A49 1CF17A49 YES
[20:07:48.092] FB03 00002000 00001000 ECB7E3EB ECB7E3EB YES
[20:07:48.108] FB04 00003000 00001000 6A3E4C8A 9B4BBBA4 NO
[20:07:48.123] FB05 00004000 00001000 DBFA66E8 DBFA66E8 YES
[20:07:48.139] FB06 00005000 00001000 B6ACDF71 B6ACDF71 YES
[20:07:48.170] FB07 00006000 00001000 BBFD90DC BBFD90DC YES
[20:07:48.186] FB08 00007000 00001000 17FB2D6A 17FB2D6A YES
[20:07:48.280] FB09 00008000 00008000 37E0F3E0 37E0F3E0 YES
[20:07:48.483] FB10 00010000 00010000 90710C55 90710C55 YES
[20:07:48.670] FB11 00020000 00010000 ABA65E29 ABA65E29 YES
[20:07:48.873] FB12 00030000 00010000 58CD51F4 58CD51F4 YES
[20:07:49.061] FB13 00040000 00010000 B940F6D9 7056FE40 NO
[20:07:49.264] FB14 00050000 00010000 53879793 53879793 YES
[20:07:49.451] FB15 00060000 00010000 DEAB7E4E DEAB7E4E YES
[20:07:49.655] FB16 00070000 00010000 DEAB7E4E DEAB7E4E YES
[20:07:49.655] kernel flash enable
[20:07:49.655] kernel blank flash page: addr: 00040000
[20:07:50.420] erased in 1 pulse(s)
[20:07:50.420] kernel write flash buffer addr: 00040000 len: 00000200
[20:07:50.514] kernel write flash buffer addr: 00040200 len: 00000200
[20:07:50.592] kernel write flash buffer addr: 00040400 len: 00000200
[20:07:50.686] kernel write flash buffer addr: 00040600 len: 00000200
[20:07:50.780] kernel write flash buffer addr: 00040800 len: 00000200
[20:07:50.858] kernel write flash buffer addr: 00040A00 len: 00000200
[20:07:50.952] kernel write flash buffer addr: 00040C00 len: 00000200
[20:07:51.030] kernel write flash buffer addr: 00040E00 len: 00000200
[20:07:51.123] kernel commit flash addr: 00040000 len: 00001000 crc32 6cab853a
[20:07:51.202] written in 1 pulse(s)
[20:07:51.202] kernel write flash buffer addr: 00041000 len: 00000200
[20:07:51.280] kernel write flash buffer addr: 00041200 len: 00000200
[20:07:51.373] kernel write flash buffer addr: 00041400 len: 00000200
[20:07:51.452] kernel write flash buffer addr: 00041600 len: 00000200
[20:07:51.545] kernel write flash buffer addr: 00041800 len: 00000200
[20:07:51.623] kernel write flash buffer addr: 00041A00 len: 00000200
[20:07:51.717] kernel write flash buffer addr: 00041C00 len: 00000200
[20:07:51.811] kernel write flash buffer addr: 00041E00 len: 00000200
[20:07:51.889] kernel commit flash addr: 00041000 len: 00001000 crc32 61658bcc
[20:07:51.952] written in 1 pulse(s)
[20:07:51.952] kernel write flash buffer addr: 00042000 len: 00000200
[20:07:57.046] kernel write flash buffer addr: 00042200 len: 00000200
[20:07:57.124] kernel write flash buffer addr: 00042400 len: 00000200
[20:07:57.218] kernel write flash buffer addr: 00042600 len: 00000200
[20:07:57.296] kernel write flash buffer addr: 00042800 len: 00000200
[20:07:57.390] kernel write flash buffer addr: 00042A00 len: 00000200
[20:07:57.468] kernel write flash buffer addr: 00042C00 len: 00000200
[20:07:57.561] kernel write flash buffer addr: 00042E00 len: 00000200
[20:07:57.655] kernel commit flash addr: 00042000 len: 00001000 crc32 313ca5d2
[20:07:57.702] written in 1 pulse(s)
[20:07:57.702] kernel write flash buffer addr: 00043000 len: 00000200
[20:07:57.796] kernel write flash buffer addr: 00043200 len: 00000200
[20:07:57.874] kernel write flash buffer addr: 00043400 len: 00000200
[20:07:57.968] kernel write flash buffer addr: 00043600 len: 00000200
[20:07:58.061] kernel write flash buffer addr: 00043800 len: 00000200
[20:07:58.140] kernel write flash buffer addr: 00043A00 len: 00000200
[20:07:58.233] kernel write flash buffer addr: 00043C00 len: 00000200
[20:07:58.311] kernel write flash buffer addr: 00043E00 len: 00000200
[20:07:58.405] kernel commit flash addr: 00043000 len: 00001000 crc32 da96703f
[20:07:58.468] written in 1 pulse(s)
[20:07:58.468] kernel write flash buffer addr: 00044000 len: 00000200
[20:07:58.561] kernel write flash buffer addr: 00044200 len: 00000200
[20:07:58.640] kernel write flash buffer addr: 00044400 len: 00000200
[20:07:58.733] kernel write flash buffer addr: 00044600 len: 00000200
[20:07:58.811] kernel write flash buffer addr: 00044800 len: 00000200
[20:07:58.905] kernel write flash buffer addr: 00044A00 len: 00000200
[20:07:58.999] kernel write flash buffer addr: 00044C00 len: 00000200
[20:07:59.077] kernel write flash buffer addr: 00044E00 len: 00000200
[20:07:59.171] kernel commit flash addr: 00044000 len: 00001000 crc32 f55644e5
[20:07:59.233] written in 1 pulse(s)
[20:07:59.233] kernel write flash buffer addr: 00045000 len: 00000200
[20:07:59.311] kernel write flash buffer addr: 00045200 len: 00000200
[20:07:59.405] kernel write flash buffer addr: 00045400 len: 00000200
[20:07:59.483] kernel write flash buffer addr: 00045600 len: 00000200
[20:07:59.577] kernel write flash buffer addr: 00045800 len: 00000200
[20:07:59.671] kernel write flash buffer addr: 00045A00 len: 00000200
[20:07:59.749] kernel write flash buffer addr: 00045C00 len: 00000200
[20:07:59.843] kernel write flash buffer addr: 00045E00 len: 00000200
[20:07:59.921] kernel commit flash addr: 00045000 len: 00001000 crc32 2663df71
[20:07:59.983] written in 1 pulse(s)
[20:07:59.983] kernel write flash buffer addr: 00046000 len: 00000200
[20:08:00.062] kernel write flash buffer addr: 00046200 len: 00000200
[20:08:00.155] kernel write flash buffer addr: 00046400 len: 00000200
[20:08:00.233] kernel write flash buffer addr: 00046600 len: 00000200
[20:08:00.327] kernel write flash buffer addr: 00046800 len: 00000200
[20:08:00.421] kernel write flash buffer addr: 00046A00 len: 00000200
[20:08:00.499] kernel write flash buffer addr: 00046C00 len: 00000200
[20:08:00.593] kernel write flash buffer addr: 00046E00 len: 00000200
[20:08:00.671] kernel commit flash addr: 00046000 len: 00001000 crc32 715eeaff
[20:08:00.733] written in 1 pulse(s)
[20:08:00.733] kernel write flash buffer addr: 00047000 len: 00000200
[20:08:00.812] kernel write flash buffer addr: 00047200 len: 00000200
[20:08:00.905] kernel write flash buffer addr: 00047400 len: 00000200
[20:08:00.983] kernel write flash buffer addr: 00047600 len: 00000200
[20:08:01.077] kernel write flash buffer addr: 00047800 len: 00000200
[20:08:06.157] reading kernel comm stats
[20:08:06.157] readback mismatch
[20:08:06.157] kernel write flash buffer addr: 00047800 len: 00000200
[20:08:08.248] readback fail
[20:08:08.248] reading kernel comm stats
[20:08:08.248] kernel error: bad command
[20:08:08.248] kernel debug:
[20:08:08.248] [FF]
[20:08:08.248] kernel write flash buffer addr: 00047800 len: 00000200
[20:08:08.326] kernel write flash buffer addr: 00047A00 len: 00000200
[20:08:08.420] kernel write flash buffer addr: 00047C00 len: 00000200
[20:08:08.498] kernel write flash buffer addr: 00047E00 len: 00000200
[20:08:08.591] kernel commit flash addr: 00047000 len: 00001000 crc32 d4e7300e
[20:08:08.607] kernel error: programming failure
[20:08:08.607] failed to commit flash at 00047000!
[20:08:08.607] failure in flashing block
[20:08:08.607] kernel flash disable
[20:08:08.607] interface close
Old Aug 16, 2015 | 06:29 AM
3gturbo's Avatar
I have 2 tablets and have flashed with win10 on both using openport 2.0
Old Aug 16, 2015 | 08:14 AM
ixbreaker's Avatar
^what version of EcuFlash did you use?
Old Sep 1, 2015 | 09:50 AM
pqek666's Avatar
any updates on this, my laptop is asking me to update to windows 10 but I don't want to get troubles with Ecuflash or Evoscan...
Old Sep 3, 2015 | 03:06 PM
aamoedo's Avatar
My Evoscan booted right up with all my saved settings still intact. I think it's a good sign. Will be plugging in and logging this weekend to verify. Fwiw, all my other setting were preserved too, including other installed programs, and even my avatar and desktop background. So far it just feels like a patch to make Windows 8 work correctly.
Old Sep 4, 2015 | 04:22 PM
Evo9_Dubai's Avatar
I upgraded and all works fine
Old Sep 12, 2015 | 06:20 PM
ridenrunwv's Avatar
Windows 7 to 10 and all is fine for me.
Old Oct 30, 2015 | 02:49 PM
wheatbix's Avatar
Yep, no issues with Windows 10. I even run it no problems on BootCamp on a Macbook Pro.
Old Dec 31, 2015 | 03:54 AM
evo_gerard's Avatar
morning guys,
i'm having a windows 10 and evoscan problem. i recently upgraded from windows 8.1 to windows 10. ecuflash works but evoscan does not work as well. if i leave the car idling the logger works fine once i start driving the logger begins to stick. it doesn't cut off but it just freezes and continues. then i look at the exel file i would see a big 1000rpm jump in the log.
i have a dell inspiron laptop i5 processor
any help would be appreciated. i have reverted to windows 8.1 but i would really like to use windows 10
thanks
Old Dec 31, 2015 | 07:11 PM
aamoedo's Avatar
Mine is working fine with 10. I don't use Ecuflash. I just flash with Evoscan. Maybe try a complete new install after upgrading to 10?
Old Feb 19, 2016 | 01:25 PM
Fox_IX's Avatar
I use ECUFlash for flashing and EvoScan for logging at the same time on Windows 10. Zero issues and the little sidebar is very useful for doing quick math calculations. Cortana is ****ing useless, but the actual search function is great.
evox4b11turbo
Jul 29, 2012 03:45 PM
germanracing
Jul 18, 2010 08:24 AM
spoolinspyder
Jul 18, 2006 03:49 AM
A-SPEC
West Region
Mar 9, 2005 11:15 AM
