changing the TPS value...
o.k., i bumped up the TPS value to 35. It is way better than before but i get one big miss when it transitions. What would happen if you set it to 0 so there is no transition??? One more question, in the timing, i see the number my ecu would run and i see the UTEC corrected number. If my ECU says it would run 18 degrees and the utec says 12 (hypotheticle) can i use this as a guide to bump up the UTEC's timing??? Ray
Re: changing the TPS value...
2. Can you log the section that causes the hesitation for me?
3. If the stock ECU would run a lot more timing in a given load site you might want to try adding a degree or so just to see what you can get away with.
-Nathan
www.turboxs.com
Yeah I noticed the same thing.. Its either the timing being different than stock at the transition point, or the MAF sensor's value jumping suddenly at the transition point..
I'm finding the same thing happens, and at 33% its not that bad since it will happen rarely in daily part throttle driving..
Possibly a revision to the FLASH to "blend" the values at the transition point so the MAF sensor and timing don't suddenly change?
Jack,
Possibly smoothing out your transitions between open and closed loop will fix it. We used to see this issue withe wrx until we got them used to smoothing of the maps. From the 0 percent column to 100. Especially the 0 column which is the closed loop portion controls.
Let us know how you make out guys.
Jermaine~
Www.turboxs.com
Jermaine~
Www.turboxs.com
I think my car's ECU is tuned more aggressively than other cars by virtue of how different the car runs compared to others.
I did notice that my car has a stumble (even stock) at about 5000 rpm and I haven't been able to get a good capture of it other than there's absolutely no knock.. I suspect its time to change my plugs again or my stock DV is leaking boost causing it to feel like its stumbling when it blows off slightly (again I can't see anything I can just feel it)
Code:
DATA1 " , , , ,Load,Knock, , , Mod, Mod, , Mod, WB " " RPM, MAP, MAF,TPS,Site,Count, Ign#1, Inj#1, Ign, Fuel,Boost, MAF, AFR" " , psia, Hz, % , , , deg , duty , deg, % ,(OL) , Hz," " 3542,+27.2, 478, 27, 00, 00, +22.6, 15.0,ECU. , +0.0,ECU. , 499, 14.65" " 3631,+27.2, 501, 27, 00, 00, +21.5, 15.0,ECU. , +0.0,ECU. , 505, 14.65" " 3732,+27.2, 520, 27, 00, 00, +21.6, 16.0,ECU. , +0.0,ECU. , 516, 14.61" " 3866,+27.2, 830, 52, 10, 00, +10.8, 31.0, +7.5, +0.2,ECU. , 939, 14.22" " 3982,+27.2,1028, 53, 10, 00, +6.8, 42.0, +8.0, +0.0,ECU. ,1207, 12.86" " 4203,+27.4,1187, 51, 30, 00, +4.0, 53.0, +8.0, -0.3,ECU. ,1196, 11.87" " 4385,+27.2,1408, 50, 40, 00, +1.2, 59.0, +8.6, -1.2,ECU. ,1196, 11.58" " 4604,+27.0,1457, 50, 60, 00, +2.7, 58.0, +8.0, -2.8,ECU. ,1096, 11.48" " 4859,+27.2,1562, 48, 70, 00, +4.8, 60.0, +8.8, -4.0,ECU. ,1436, 11.62" " 5104,+27.2,1677, 46, 70, 03, +7.1, 62.0,+10.0, -6.1,ECU. ,1358, 11.68" " 5307,+27.2,1519, 42, 80, 00, +7.1, 62.0, +9.3, -6.8,ECU. ,1445, 11.62" " 5518,+27.4,1592, 41, 80, 00, +7.2, 65.0,+10.1, -8.6,ECU. ,1420, 11.71" " 5649,+27.2,1344, 35,100, 00, +10.1, 59.0, +9.6, -7.5,ECU. ,1282, 11.67" " 5473,+27.2, 153, 10, 00, 00, +28.4, 5.0,ECU. , +0.0,ECU. , 132, 11.34" " 5089,+27.2, 87, 0, 00, 00, +38.2, 5.0,ECU. , +0.0,ECU. , 71, 12.27" " 4681,+27.0, 132, 0, 00, 00, +28.2, 5.0,ECU. , +0.0,ECU. , 66, 13.65" " 4391,+27.2, 378, 21, 00, 00, +34.7, 10.0,ECU. , +0.0,ECU. , 430, 13.68" " 4084,+27.0, 542, 36, 10, 00, +26.9, 19.0, +8.0, +0.0,ECU. , 612, 13.78" " 4161,+27.0, 783, 46, 10, 00, +17.8, 26.0, +8.0, +0.0,ECU. , 862, 13.47" " 4235,+27.2,1006, 50, 10, 00, +11.8, 36.0, +8.0, +0.0,ECU. , 984, 12.56"
I have the same hesitation/stumble here too.
My Utec came with TPS set to 35% and the hesitation/stumble was pretty noticeable. I lower it to 33% and it does seems to help a bit but it's still there. One time I even got a knock count (CEL flash) right when I step on the gas paddle to give it more gas during take off.
Here's one stop-go-stop log with TPS set to 33%.
Code:
RPM, MAP, MAF, TPS, Site, Count, Ign#1, Inj#1, Ign, Fuel, Boost, MAF, AFR 862 +25.5 29 1 00 00 +3.2 1.0 ECU. +0.0 ECU. 28 857 +25.5 28 1 00 00 +4.3 1.0 ECU. +0.0 ECU. 28 875 +25.5 29 1 00 00 +3.2 1.0 ECU. +0.0 ECU. 29 850 +25.5 28 1 00 00 +4.2 1.0 ECU. +0.0 ECU. 28 867 +25.5 28 1 00 00 +3.2 1.0 ECU. +0.0 ECU. 29 864 +25.5 28 1 00 00 +4.2 1.0 ECU. +0.0 ECU. 28 854 +25.7 29 1 00 00 +3.2 1.0 ECU. +0.0 ECU. 28 844 +25.7 29 1 00 00 +3.2 1.0 ECU. +0.0 ECU. 28 860 +25.7 28 1 00 00 +5.3 1.0 ECU. +0.0 ECU. 27 862 +25.7 29 1 00 00 +2.2 1.0 ECU. +0.0 ECU. 29 863 +25.5 44 3 00 00 +4.2 0.0 ECU. +0.0 ECU. 150 1153 +25.3 165 52 10 00 +4.3 4.0 +18.0 +0.0 61.00 147 1654 +25.3 44 1 00 00 +14.8 1.0 ECU. +0.0 ECU. 43 1341 +25.1 181 20 00 00 +21.0 7.0 ECU. +0.0 ECU. 176 1420 +25.3 146 24 00 00 +14.8 5.0 ECU. +0.0 ECU. 131 1446 +25.3 151 25 00 00 +16.1 5.0 ECU. +0.0 ECU. 150 1434 +25.5 141 30 00 00 +13.3 5.0 ECU. +0.0 ECU. 158 1404 +25.5 173 30 00 00 +12.3 5.0 ECU. +0.0 ECU. 150 1338 +25.5 144 30 00 00 +11.3 5.0 ECU. +0.0 ECU. 133 1425 +25.5 173 31 00 00 +11.1 5.0 ECU. +0.0 ECU. 142 1668 +25.5 163 33 10 00 +13.2 7.0 +14.6 +0.0 ECU. 208 1874 +25.5 203 33 10 00 +15.1 8.0 +13.0 +0.0 ECU. 238 2072 +25.5 246 33 10 00 +17.4 9.0 +11.4 +0.0 ECU. 239 2357 +25.5 274 30 00 00 +18.5 10.0 ECU. +0.0 ECU. 249 2540 +25.3 242 26 00 00 +19.8 10.0 ECU. +0.0 ECU. 259 2741 +25.3 278 26 00 00 +22.8 10.0 ECU. +0.0 ECU. 281 2976 +25.5 294 25 00 00 +27.0 11.0 ECU. +0.0 ECU. 284 3124 +25.5 279 25 00 00 +27.5 10.0 ECU. +0.0 ECU. 282 3267 +25.5 213 23 00 00 +29.7 8.0 ECU. +0.0 ECU. 209 3280 +25.5 45 3 00 00 +36.8 6.0 ECU. +0.0 ECU. 37 2997 +25.5 166 2 00 00 +44.8 3.0 ECU. +0.0 ECU. 44 2745 +25.5 221 1 00 00 +25.6 3.0 ECU. +0.0 ECU. 29 2544 +25.5 31 2 00 00 +20.7 3.0 ECU. +0.0 ECU. 32 2270 +25.5 36 1 00 00 +16.4 3.0 ECU. +0.0 ECU. 38 2056 +25.3 35 5 00 00 +21.1 2.0 ECU. +0.0 ECU. 42 2184 +25.3 50 9 00 00 +25.5 2.0 ECU. +0.0 ECU. 58 2177 +25.3 126 16 00 00 +35.2 4.0 ECU. +0.0 ECU. 124 2115 +25.7 127 16 00 00 +33.5 5.0 ECU. +0.0 ECU. 129 2243 +25.9 176 21 00 00 +31.5 6.0 ECU. +0.0 ECU. 180 2314 +25.9 169 21 00 00 +31.5 7.0 ECU. +0.0 ECU. 181 2417 +25.9 188 21 00 00 +30.5 7.0 ECU. +0.0 ECU. 183 2493 +25.5 191 22 00 00 +31.5 7.0 ECU. +0.0 ECU. 209 2523 +25.3 211 24 00 00 +28.4 8.0 ECU. +0.0 ECU. 212 2600 +25.3 224 25 00 00 +26.7 9.0 ECU. +0.0 ECU. 225 2651 +25.3 237 25 00 00 +27.7 9.0 ECU. +0.0 ECU. 249 2736 +25.3 264 26 00 00 +26.7 10.0 ECU. +0.0 ECU. 269 2829 +25.3 303 28 00 00 +25.6 11.0 ECU. +0.0 ECU. 300 2916 +25.3 344 30 00 00 +23.5 13.0 ECU. +0.0 ECU. 349 3011 +25.7 402 35 10 00 +20.8 15.0 +8.0 +0.0 ECU. 442 3183 +25.5 570 46 10 00 +16.6 20.0 +7.4 +0.0 66.00 529 3313 +25.5 574 46 10 00 +12.8 24.0 +7.0 +0.0 66.00 561 3447 +25.7 677 43 10 00 +9.6 28.0 +7.0 +0.0 63.00 728 3615 +25.5 690 39 10 00 +10.7 31.0 +7.0 +0.0 ECU. 620 3800 +25.7 652 35 10 00 +12.7 29.0 +7.0 +0.0 ECU. 649 3944 +25.3 629 35 10 00 +15.0 28.0 +7.0 +0.0 ECU. 644 4084 +25.3 415 28 00 00 +21.7 16.0 ECU. +0.0 ECU. 324 3954 +25.3 338 6 00 00 +41.1 4.0 ECU. +0.0 ECU. 139 3699 +25.3 88 2 00 00 +38.0 5.0 ECU. +0.0 ECU. 145 3367 +25.5 261 2 00 00 +33.9 4.0 ECU. +0.0 ECU. 48 3060 +25.3 50 2 00 00 +40.9 3.0 ECU. +0.0 ECU. 25 2808 +25.5 64 2 00 00 +34.5 2.0 ECU. +0.0 ECU. 28 2705 +25.3 49 7 00 00 +27.5 2.0 ECU. +0.0 ECU. 57 2861 +25.3 116 15 00 00 +41.6 4.0 ECU. +0.0 ECU. 120 2873 +25.3 134 17 00 00 +42.6 5.0 ECU. +0.0 ECU. 129 2871 +25.3 177 18 00 00 +42.6 5.0 ECU. +0.0 ECU. 170 2868 +25.3 203 22 00 00 +36.6 7.0 ECU. +0.0 ECU. 216 2921 +25.3 239 25 00 00 +31.6 9.0 ECU. +0.0 ECU. 244 2931 +25.3 253 25 00 00 +29.6 9.0 ECU. +0.0 ECU. 245 2994 +25.5 287 27 00 00 +28.6 10.0 ECU. +0.0 ECU. 306 3035 +25.7 340 31 00 00 +25.7 12.0 ECU. +0.0 ECU. 334 3060 +25.9 370 31 00 00 +23.5 14.0 ECU. +0.0 ECU. 377 3138 +25.9 396 31 00 00 +21.5 14.0 ECU. +0.0 ECU. 400 3223 +25.9 424 31 00 00 +20.7 16.0 ECU. +0.0 ECU. 420 3261 +25.7 465 31 00 00 +20.8 17.0 ECU. +0.0 ECU. 461 3340 +25.5 508 32 00 00 +18.7 19.0 ECU. +0.0 ECU. 526 3429 +25.5 591 33 10 00 +16.6 22.0 +7.0 +0.0 ECU. 570 3508 +25.5 618 35 10 00 +14.0 26.0 +7.0 +0.0 ECU. 641 3595 +25.3 651 35 10 00 +12.8 27.0 +7.0 +0.0 ECU. 615 3663 +25.3 638 35 10 00 +12.8 28.0 +7.0 +0.0 ECU. 617 3766 +25.3 688 35 10 00 +13.8 29.0 +7.0 +0.0 ECU. 652 3849 +25.3 685 36 10 00 +13.9 29.0 +7.0 +0.0 ECU. 686 3930 +25.3 675 35 10 00 +13.9 30.0 +7.0 +0.0 ECU. 724 4040 +25.3 683 35 10 00 +15.0 30.0 +7.0 +0.0 ECU. 683 4095 +25.3 631 34 10 00 +16.7 28.0 +7.0 +0.0 ECU. 670 4187 +25.1 630 33 10 00 +19.0 26.0 +7.0 +0.0 ECU. 588 4208 +25.5 526 32 00 00 +21.1 25.0 ECU. +0.0 ECU. 592 4345 +25.3 574 32 00 00 +22.7 24.0 ECU. +0.0 ECU. 588 4420 +25.7 559 32 00 00 +21.8 24.0 ECU. +0.0 ECU. 548 4504 +25.7 624 33 10 00 +21.1 26.0 +7.9 +0.0 ECU. 644 4535 +25.7 506 32 00 00 +21.7 25.0 ECU. +0.0 ECU. 596 4597 +25.7 563 32 00 00 +26.1 23.0 ECU. +0.0 ECU. 573 4662 +25.5 551 31 00 00 +26.1 23.0 ECU. +0.0 ECU. 551 4721 +25.5 557 31 00 00 +26.1 23.0 ECU. +0.0 ECU. 568 4768 +25.3 545 31 00 00 +26.1 23.0 ECU. +0.0 ECU. 553 4837 +25.3 540 31 00 00 +27.2 23.0 ECU. +0.0 ECU. 533 4887 +25.3 489 31 00 00 +27.1 22.0 ECU. +0.0 ECU. 527 4916 +25.3 483 30 00 00 +28.2 21.0 ECU. +0.0 ECU. 444 4823 +25.3 388 11 00 00 +32.2 17.0 ECU. +0.0 ECU. 216 4694 +25.5 116 2 00 00 +38.2 6.0 ECU. +0.0 ECU. 39 4317 +25.5 149 2 00 00 +35.9 4.0 ECU. +0.0 ECU. 54 4011 +25.5 22 1 00 00 +28.1 4.0 ECU. +0.0 ECU. 30 3703 +25.5 33 2 00 00 +21.0 4.0 ECU. +0.0 ECU. 39 3546 +25.5 50 1 00 00 +17.7 4.0 ECU. +0.0 ECU. 54 3542 +25.5 59 1 00 00 +21.6 4.0 ECU. +0.0 ECU. 67 3483 +25.5 67 1 00 00 +21.6 4.0 ECU. +0.0 ECU. 60 3468 +25.5 66 1 00 00 +21.6 4.0 ECU. +0.0 ECU. 60 3443 +25.5 61 1 00 00 +21.6 4.0 ECU. +0.0 ECU. 60 3422 +25.5 62 1 00 00 +21.5 4.0 ECU. +0.0 ECU. 57 3404 +25.5 62 1 00 00 +22.7 4.0 ECU. +0.0 ECU. 59 3401 +25.5 60 1 00 00 +21.5 4.0 ECU. +0.0 ECU. 60 3363 +25.5 57 1 00 00 +21.5 4.0 ECU. +0.0 ECU. 57 3353 +25.5 79 6 00 00 +30.7 10.0 ECU. +0.0 ECU. 100 3353 +25.3 105 15 00 00 +42.7 5.0 ECU. +0.0 ECU. 112 3387 +25.5 219 23 00 00 +41.7 9.0 ECU. +0.0 ECU. 237 3360 +25.5 320 30 00 00 +30.7 11.0 ECU. +0.0 ECU. 327 3336 +25.3 361 34 10 00 +27.9 14.0 +7.0 +0.0 ECU. 369 3380 +25.5 436 35 10 00 +22.6 17.0 +7.0 +0.0 ECU. 492 3401 +25.5 495 35 10 00 +19.9 19.0 +7.0 +0.0 ECU. 483 3447 +25.3 594 35 10 00 +17.8 21.0 +7.0 +0.0 ECU. 556 3483 +25.5 613 35 10 00 +15.0 25.0 +7.0 +0.0 ECU. 609 3523 +25.3 595 35 10 00 +13.8 27.0 +7.0 +0.0 ECU. 631 3572 +25.3 635 35 10 00 +14.0 27.0 +7.0 +0.0 ECU. 599 3619 +25.5 641 35 10 00 +13.8 27.0 +7.0 +0.0 ECU. 641 3671 +25.5 665 35 10 00 +13.9 27.0 +7.0 +0.0 ECU. 632 3683 +25.5 594 35 10 00 +15.0 27.0 +7.0 +0.0 ECU. 637 3667 +25.5 1567 18 00 00 +27.9 9.0 ECU. +0.0 ECU. 603 3783 +25.3 91 4 00 00 +31.9 4.0 ECU. +0.0 ECU. 261 3720 +25.1 140 2 00 00 +36.8 5.0 ECU. +0.0 ECU. 119 3691 +25.1 79 2 00 00 +34.7 5.0 ECU. +0.0 ECU. 59 3658 +25.1 61 2 00 00 +21.7 4.0 ECU. +0.0 ECU. 31 3631 +25.1 30 2 00 00 +17.7 4.0 ECU. +0.0 ECU. 66 3607 +25.3 43 2 00 00 +17.8 4.0 ECU. +0.0 ECU. 48 3584 +25.3 59 1 00 00 +21.6 4.0 ECU. +0.0 ECU. 63 3572 +25.3 62 2 00 00 +21.5 4.0 ECU. +0.0 ECU. 63 3546 +25.3 61 2 00 00 +21.7 4.0 ECU. +0.0 ECU. 60 3542 +25.3 63 1 00 00 +21.7 4.0 ECU. +0.0 ECU. 59 3512 +25.5 62 2 00 00 +21.6 4.0 ECU. +0.0 ECU. 64 3486 +25.5 64 1 00 00 +21.5 4.0 ECU. +0.0 ECU. 66 3472 +25.5 59 1 00 00 +21.5 4.0 ECU. +0.0 ECU. 60 3479 +25.5 59 1 00 00 +21.6 4.0 ECU. +0.0 ECU. 62 3439 +25.5 61 1 00 00 +21.5 4.0 ECU. +0.0 ECU. 60 3415 +25.5 59 1 00 00 +21.6 4.0 ECU. +0.0 ECU. 61 3401 +25.5 63 2 00 00 +22.6 4.0 ECU. +0.0 ECU. 57 3394 +25.5 60 2 00 00 +21.7 4.0 ECU. +0.0 ECU. 61 3367 +25.5 58 1 00 00 +21.6 4.0 ECU. +0.0 ECU. 59 3367 +25.5 57 1 00 00 +21.6 4.0 ECU. +0.0 ECU. 57 3323 +25.5 57 2 00 00 +21.6 4.0 ECU. +0.0 ECU. 61 3290 +25.3 59 1 00 00 +21.5 4.0 ECU. +0.0 ECU. 61 3284 +25.3 60 2 00 00 +22.6 4.0 ECU. +0.0 ECU. 56 3248 +25.5 59 2 00 00 +22.7 4.0 ECU. +0.0 ECU. 58 3208 +25.5 59 1 00 00 +22.6 4.0 ECU. +0.0 ECU. 55 3165 +25.5 57 2 00 00 +21.6 4.0 ECU. +0.0 ECU. 56 3126 +25.5 56 1 00 00 +22.6 4.0 ECU. +0.0 ECU. 56 3075 +25.5 57 1 00 00 +22.5 4.0 ECU. +0.0 ECU. 52 3019 +25.5 57 2 00 00 +22.5 4.0 ECU. +0.0 ECU. 55 2955 +25.5 51 1 00 00 +22.6 4.0 ECU. +0.0 ECU. 54 2911 +25.5 53 1 00 00 +21.3 4.0 ECU. +0.0 ECU. 52 2846 +25.5 53 2 00 00 +21.5 4.0 ECU. +0.0 ECU. 49 2789 +25.5 52 1 00 00 +20.8 4.0 ECU. +0.0 ECU. 51 2707 +25.5 49 1 00 00 +20.6 4.0 ECU. +0.0 ECU. 50 2666 +25.5 51 1 00 00 +19.7 4.0 ECU. +0.0 ECU. 49 2590 +25.5 52 2 00 00 +19.7 4.0 ECU. +0.0 ECU. 47 2527 +25.5 46 1 00 00 +18.6 4.0 ECU. +0.0 ECU. 49 2454 +25.5 46 2 00 00 +18.5 4.0 ECU. +0.0 ECU. 46 2392 +25.5 44 1 00 00 +18.5 4.0 ECU. +0.0 ECU. 45 2331 +25.5 42 1 00 00 +17.5 4.0 ECU. +0.0 ECU. 41 2273 +25.5 39 1 00 00 +17.4 4.0 ECU. +0.0 ECU. 36 2192 +25.5 37 1 00 00 +17.5 4.0 ECU. +0.0 ECU. 37 2153 +25.5 34 1 00 00 +16.3 4.0 ECU. +0.0 ECU. 33 2082 +25.3 31 1 00 00 +15.2 4.0 ECU. +0.0 ECU. 31 2015 +25.5 30 1 00 00 +15.2 4.0 ECU. +0.0 ECU. 31 1939 +25.5 32 1 00 00 +14.6 4.0 ECU. +0.0 ECU. 31 1869 +25.5 31 1 00 00 +13.5 4.0 ECU. +0.0 ECU. 32 1807 +25.5 30 1 00 00 +11.3 4.0 ECU. +0.0 ECU. 30 1715 +25.3 31 1 00 00 +10.3 4.0 ECU. +0.0 ECU. 31 1651 +25.3 31 1 00 00 +8.1 4.0 ECU. +0.0 ECU. 32 1460 +25.5 32 1 00 00 +6.3 4.0 ECU. +0.0 ECU. 30 1211 +25.3 31 1 00 00 +9.8 1.0 ECU. +0.0 ECU. 31 982 +25.5 30 1 00 00 +13.5 1.0 ECU. +0.0 ECU. 30 866 +25.5 29 1 00 00 +12.5 1.0 ECU. +0.0 ECU. 30 892 +25.5 29 1 00 00 +9.0 1.0 ECU. +0.0 ECU. 29 867 +25.5 30 1 00 00 +5.3 1.0 ECU. +0.0 ECU. 31 868 +25.5 29 1 00 00 +7.4 1.0 ECU. +0.0 ECU. 29
your getting the stumble because when it switches over from your stock ECU to the UTEC, the values between the two are slightly different (in my case its timing) if you look at your map, compare the ECU lines where your TPS Just transitions over from 30% or so.. I was told to try to adjust the map for the first load site so the timing and fuel is closer to what you see stock, this way it will transition smoother and won't be as noticable.. (Lower RPM's and low Load cells)
I've noticed that when you look at when you get stumbling, there's a significant difference in the ECU's desired timing, and the modified timing.. hence stumble.. I didn't see a dramatic change in MAF readings (modified vs stock) that could be interpretted as an interruption in the signal..
"rraulston" Your knock events looks like you are running too much timing in that load zone. Looks like it starts here:
Notice that the ecu is only wanting to run 6.8 degrees timing. The look at the logs after that the UTEC timing stays at +8 but the ecu wants to run WAY less. Big sign that you are close to knock. Shame we can't see what boost you were running at that point. It's great that you have the WB, nice to be able to see AFR in the logs. Thats why I say your knock is timing created.
Remove some timing in those load zones.
i have had no knock all along and now this partial load knock. I think when i topped off at a generic station yesterday might have somthing to do with it. Ill be purging the tank and trying again. Also was a hot day yesterday.
Possibly, but keep in mind that you were probably tuning for WOT runs and not logging continuously and watching for part throttle drivability and the load sites related to it..
Ok, let me try to clarify what I mean.. With your aftermarket exhaust, and (possibly if you have one) an aftermarket air filter, the turbo will hit peak boost at part throttle, in some cases needing slightly more fuel or a bit of timing adjustment that is in some conditions, significantly different than your WOT conditions..
Now that you have your WOT stuff dialed in, your going to have to adjust your drivability, you might want to adjust the boost to be a bit lower (18psi or so) to significantly lower at much lower TPS values (lower load sites) it has advantages in drivability and fuel mileage too..
Part throttle under boost means that you may find that the DV (BOV) may be in a partial state of being open, lowering the boost will help that at part throttle because it won't force the valve open as often when the boost drops (but doesn't quite fall into a vacuum state)
Vivid Racing
13
May 27, 2007 02:45 PM
EVO8LTW
Jun 20, 2005 09:24 AM
