Noob wondering about pops n bangs
Old Jul 19, 2017 | 03:53 PM
D1andonlyantman's Avatar
Hi. Sometimes when I let off at high rpm in 5th or 6th I get some pretty huge flames. I've put this partially down to my BOV making it go rich for a second and also I assume it's slightly overfuelling in that range, because the flames are pretty impressive.... I'm fitting my wideband afr this weekend and already have evoscan, so I'll be able to know for sure what's happening. But that's got me wondering. to map in pops and bangs don't people generally pull timing? So what's wrong with just adding more fuel in certain areas in the fuel map which is what I'm guessing has caused my flame show? And assuming that's not a good way to map it in, how would you safely go about mapping it in so it's a bit flamey at the top of the rev range? Do a data log and see what's going on in the higher revs and then slowly start pulling timing? I realise there's a few different questions in here and probably lots of fail, but I'm not an idiot and have been reading some of merlins guide, so if anyone wouldn't mind taking the time to explain things to a bit of a Noob that is eager to learn, I'd appreciate it.
thanks
Old Jul 19, 2017 | 05:12 PM
4G63_EVO's Avatar
Guessing its something like this?
Old Jul 20, 2017 | 12:33 AM
Yeah mate, basically. If I do a big pull at night I can see the road ahead of me at the sides glowing orange for a couple of seconds. A friend who was following said they were pretty damn big
Donnyevo7
Feb 27, 2016 03:10 PM
garystanfield23
Jan 9, 2016 12:06 PM
Waffled
Jan 19, 2015 01:53 PM
jameswwt
Sep 27, 2010 09:26 AM
schmartz18
Aug 26, 2010 05:07 PM
