Running rich at wot after having it tuned
Hello, just as the title states I'm running rich at wide open throttle. My af meter reads between 7 and 8 and my injectors are maxing out according to my log in link ecu.
I had just bought the car and brought it to a tuner shop, they ran lots of tests, and tuned it for e85. I was having some issues with what I didn't know at the time where just the limiters, and decided to do a boost leak test. The car would not hold 3 psi even, I had dry rotted silicone couplers, and massive leaks. I replaced all of that, and now it is leak free. I contacted the shop, and they said they did a boost leak test first and it passed just fine, and then they tuned it.
Well now my afr is around 8 at WOT. Could this be from something else? Should I turn the boost up, I'm at stock setting with some crazy built evo 9 turbo? Should I tell my tuner he is a liar about doing a boost leak test? I'm kinda lost, I emailed the shop my log earlier, just hoping for some insight.
I had the shop install link ecu, fic 1100 injectors before the tune. The car has fullblow twin walbro 255hps, and a fuelab fpr.
sounds like they tuned it with the boost leak, i would stay out of boost and take it to different shop or see if someone on here can do a remote tune for you. stay away from the shop that has worked on the car. they are going to blow your **** up.
Oh man, I'll start looking for new tuners. They were the only one I knew of that had an all wheel drive dyno.
Not sure if it has that, I didn't build the car. I'll look into that and get back to you.
I just read some of the description in the original add and it says both pumps on all the time. Here is a link to the original owners mod list.
https://www.evolutionm.net/forums/sa...lots-more.html
REDEVO1113
14
Oct 22, 2019 10:09 AM
Ferp
Apr 17, 2018 10:06 PM
Mad_SB
May 10, 2011 02:29 PM
