Rich idle, cruise, stumble
well, it’s still doing this crap...I noticed the cooler or humid it is out the worse it gets...tuber thought voltage was dropping and suggested new battery but battery tested good...u guys have any other ideas?
OP, did you ever try a new or known good MAP sensor?
Car used to run fine...I switched the Omni 4 bar with my friends and it was the same so that’s ruled out...it has an iat sensor...it gets worse when humid or cold but still does it when normal out...
For those who haven't yet figured it out......
SD means speed density.
The density part of it means air density IN the intake manifold.
That is measured using a MAP sensor for the pressure part of it.
It is measured with an IAT sensor for the temperature part of it.
Air pressure IN the manifold and air temperature IN the manifold make density IN the manifold.
Fuel temp will never work accurately because fuel temperature is not air temperature.
In which case it isn't an SD tune it's a SP(speed pressure) tune which nobody uses because it doesn't work accurately enough.
If you're not worried about accuracy then just stick a carburettor on it.
Maybe mr wannagetitdone should stop posting bull**** information?
edit......you need a new toooooner too.
Fancy suggesting you need a new battery?
Stop paying a boy to do a man's job.
So you don't agree on the definition of "speed density" then?
You're a "tooner " too?
That's right....you've been toooning for 20 years and using a WB for 20 years but they've only been on the market a bit over 15 years.
This man knows a bit.
Just a bit.
Reverting to a MAF tune will fix most of it.
Not all of it.
Just a bit.
Not all of it.
Can’t see his posts anymore however to speak to the “you need an IAT” comment that was quoted above, ummm no, just no.
Been through all seasons on SD w/o an IAT and the car runs fine. Please get a life. Thanks
First of all, don't state I said something I didn't and secondly, Bosch would 100% disagree
