zeitronix/evoscan/log
Old Sep 20, 2017 | 10:41 AM
i8Godzilla's Avatar
I'm a little confused and yes I googled. I am not that new to the scene I come from 10yrs breaking dsms lol.
I am currently trying to get a data log out of my 2005 e8 ssl using Zeitronix zt2 and Evoscan.
I have the serial to usb adaptor and I can log through zeitronix, but I want tolog through evoscanand use the zeitronix wb and the map sensor and why not use the egt as well and log them. so my question is how can I log all 3 of my zeitronix sensor in evoscan..
mods that I know of
zietronix- egt tapped #2 runner
zietronix- map sensor doesn't say the size that I can see (3bar,4bar etc)
zeitronix- wb
I should also add that I have the lcd screen display
injen intake pipe
recirc bov evoX
injen uicp
genuine Apexi cat-back exhaust
the rest is unkown at this point.
Old Sep 20, 2017 | 10:50 AM
Biggiesacks's Avatar
You need to connect a serial cable to the zeitronix brain and plug it into your laptop. Identify the comport the cable is on and then in evoscan you need to select zeitronix as your external wideband and its associated com port , then check "External Wideband A/F ratio", and the ZTX * items from the list of things to log.
Old Sep 20, 2017 | 11:00 AM
i8Godzilla's Avatar
Let me make sure I'm not missing something or I didn't explain or maybe I'm still lost for a slight second. I currently have a serial cable coming from under the dash on the passenger side just like I would assume it would since the ecu is in that area as well as the zt2 lcd display. I have a SEWELL serial to usb adaptor and the correct drivers installed as zeirtonix works fine. The Lcd display is on while logging in "Zeitronix" now are you saying there should be A "separate" serial cable than the one I use to log zeitronix?
Old Sep 20, 2017 | 11:03 AM
no just 1 serial cable, but you cant log in the zeitronix app and evoscan at the same time, or at least i don't think you can. either way if you want a single concise log you need to be logging everything in evoscan alone. Also just to be clear you need an openport cable also plugged into your OBDII port to log the MUTIII data from your cars ecu. So your laptop has 2 things plugged into it, the openport cable plugged into obdII port and the serial-usb converter plugged into your zeitronix.
Old Sep 20, 2017 | 11:28 AM
i8Godzilla's Avatar
Yes, I understand that I cannot log both at the same time or if you can I am not sure, but that isn't my question.
The later part kind of answered my question.
I should probably state I have the openport2.0 TACTRIX cable as well.
I guess I'll just go see what all logs in Evoscan. Maybe my question is being asked wrong:/
I have 3 different zeitronix sensors and I just want to be sure that ALL 3 (wb,map,egt) will be logged not just the AFR in evoscan. Hope I explained myself better.
I'm just trying to log with evoscan to be clear.
I was just stating that zeitronix logs fine and that I want all 3 sensors logged in evoscan
Old Sep 20, 2017 | 11:30 AM
I have 3 different zeitronix sensors and I just want to be sure that ALL 3 will be logged not just the AFR. Hope I explained myself better.
Yah thats what the other "ZTX" options in evoscan are for, logging the other sensors hooked up to your zeitronix. I don't have much experience with those elements specifically so i cant tell you if you need to add in your own formulas etc, but im sure some google-fu will get you the answers on that aspect.
Old Sep 20, 2017 | 11:44 AM
i8Godzilla's Avatar
Gotcha!! I appreciate your help see what I can dig up. Everything I was finding was just logging one sensor. So I wasn't sure if I need to do something as far as tapping into those so that evoscan could log or if it would do it like you're saying in the settings.
EDIT: yes zeitonix will split and pick up each sensor and log it in evoscan. plug both zeitronix usb in as well as evoscan usb and select from the drop down menu which "ZTX"sensors you have. enjoy!!
Old Jul 22, 2018 | 03:04 AM
Thugline's Avatar
so you were able to log egt and boost as well by just doing that?
Thugline
May 4, 2015 08:35 AM
Evo_Jay
Oct 15, 2009 01:05 AM
UndieStainz
AEM EMS
16
Sep 28, 2006 03:50 AM
500whp.com
40
May 18, 2006 10:29 AM
