Installed hallman MBC, Making less boost and is slow
Old Nov 15, 2017 | 12:26 PM
shane_evo7's Avatar
Hello all,
I just installed a Hallman mbc pro on my jdm evo 7,
the car was running stock boost before
after installing the mbc and having it turned all the way down just to test,
the car is making less boost and is extremely slow, it builds like .5 bar and then it slowly climbs to just under 1 bar.
any ideas as to why it is lower than stock now?
thanks
Old Nov 15, 2017 | 12:48 PM
nikush's Avatar
Because your wastegate is weak.
Old Nov 22, 2017 | 09:25 AM
revzilla's Avatar
Can you post pictures of how you installed it?
Old Nov 23, 2017 | 10:43 PM
LetsGetThisDone's Avatar
Turned boost all the way down (turned the hallman counterclockwise), or turn the hallman “down” to turn boost up (turned the hallman clockwise)?
Is it’s the hallman pro, or standard?
Did you hook the hallman up to the stock wastegate solenoid lines, or did you run new lines?
bboyalan
Aug 28, 2015 12:45 AM
eisnikesb
Jul 7, 2014 07:44 PM
My03evo
Aug 29, 2011 11:04 PM
justboosted02
Jun 29, 2009 11:12 PM
Dade County
Dec 23, 2006 06:39 AM
