Evo 8 issues.
Old Mar 28, 2018 | 02:15 PM
  #31
Smoknzx3's Avatar
Nothing else it could be man. Not that I know of. It looks like the crank to me
  #32
Biggiesacks's Avatar
ouch that sucks. I think thats probably a balance shaft, or one of those balance shaft eliminator deals. Either way, though your gonna be building a new engine.
Old Mar 28, 2018 | 02:40 PM
  #33
2006EvoIXer's Avatar
Crankshaft would be thick. I'm thinking it's your bance shaft but why would that fail? Maybe a broken rod behind that? This sucks.
Old Mar 30, 2018 | 07:13 AM
  #34
Smoknzx3's Avatar
Shoot, I don’t know. I was doing 15MPH when it let go. Not even 2k rpms. I bought the car a couple months ago when the owner had one of the rods replaced. The shop has a good reputation with tuned power cars and before I bought it I had the shop go through the rest of the motor to see if there were any other issues. They said no. What causes this? It’s almost like where the balancing shaft slides in became unseated. Thankfully I wasn’t going fast. It’s odd though the car ran good other than the boost cut out, but I never ran it in boost I just used it to drive two miles maybe once a week. I see MAP has a short block 2.4 for $2,200 I’m pretty sure I can just transplant the head and other goodies over. Ideas from you guys?
Old Mar 30, 2018 | 07:46 AM
  #35
What kind of power do you want?
Old Mar 30, 2018 | 09:11 AM
  #36
Smoknzx3's Avatar
It had 500ish, that’s where it can stay
  #37
Smoknzx3's Avatar
FP green and cams
Old Mar 30, 2018 | 09:24 AM
  #38
500 is where the stock bottom end usually gives up the ghost so your failure is actually pretty normal.
Old Mar 30, 2018 | 09:41 AM
  #39
Smoknzx3's Avatar
All the internals were forged. Eagle rods.
Old Mar 30, 2018 | 09:47 AM
  #40
bummer, your engine builder have any theories on what failed?
Old Mar 30, 2018 | 09:48 AM
  #41
Smoknzx3's Avatar
No not yet. It hasn’t been brought anywhere. I bought it nodded like this
Old Mar 30, 2018 | 10:01 AM
  #42
Since you noted that you saw the car in the shop with the engine apart before you bought it, maybe that shop has a warranty on the work...worth giving them a call, maybe talk to the tech who worked on it, he might have some insight on why it failed too.
Old Mar 30, 2018 | 10:26 AM
  #43
Smoknzx3's Avatar
Yes, I will be doing that but I wanted to get some insite here first. Any other ideas on if the rod replacement could have caused this issue? Install errors? Anything.
Old Mar 30, 2018 | 10:52 AM
  #44
Either installation error or bad break in. We should have a better picture once block is opened up. Personally, I'd lean towards installation error if quality parts. Butyou know that the shop will fight that tooth & nail.
Old Mar 30, 2018 | 11:28 AM
  #45
Smoknzx3's Avatar
Yeah that’s my thoughts as well. Unless I can prove they did something wrong it’s probably not worth the effort. When I’m not pissed I’ll pull the oil pan and look it over.
