Evo IX bad idle PLEASE HELP
Old Feb 26, 2018 | 09:48 PM
C0dyix's Avatar
Originally Posted by 2006EvoIXer
That is strange. Sounds like a loose wire or something loose.
i didnt notice anything out of sorts or beat up when i was cleaning the tb today ill look closer tomorrow morning when i disconnect the battery
Old Feb 26, 2018 | 10:45 PM
2006EvoIXer's Avatar
Originally Posted by C0dyix
stock block and turbo, buschur front mount, buschur exhaust, small battery, 1000cc injectors and an aem 320 fuel pump
Can't see any of these causing the problem.
Very strange.
Old Feb 26, 2018 | 11:59 PM
RightSaid fred's Avatar
It's pointless trying to clean a throttle body.
There's 3 things that can make them stick.
A worn shaft
Improper adjustment of the throttle stop.
Freezing due to cold weather.
Old Mar 1, 2018 | 07:51 PM
400s's Avatar
Can you log the car?
Throttle position,rpm, target idle rpm, timing, afr, injector pulse width, isc steps, iscv demand, iscv position, Isc learn (ac on and ac off) load, boost..
otherwise you will get 20 different answers.
nlp187
Jul 8, 2012 10:32 PM
Toxin
15
Mar 14, 2009 12:47 PM
bruce2341
AEM EMS
13
Aug 23, 2008 01:29 PM
tt412
Jun 8, 2005 05:54 PM
