logging load
Old Apr 5, 2018 | 07:45 PM
nor11384's Avatar
FCOTM Winner
logging load
Hey guys Ive been trying to log load so I can make adjustments but load mut 2byte mod at idle reads in the 70 - 80 range and 1byte load reads 38 - 40 range. 2byte seems way high and 1byte load seems pretty high too. What should load be at idle? I just want to make sure that the value evoscan is reading is correct. I'm guessing 1byte load is the one to look at. Can someone confirm that these readings are good?
Old Apr 5, 2018 | 10:38 PM
LetsGetThisDone's Avatar
38-40 sounds right.
Sounds like something is wrong with the 2byte logging. It should be the same. I want to say their is something you have to change in the rom for it to log right.
Old Apr 6, 2018 | 11:46 AM
nor11384's Avatar
FCOTM Winner
Been reading all ylthebthreads but can’t figure it out. As long as 1byte is correct I can make adjustments accordingly.
Old Apr 6, 2018 | 12:56 PM
evo9_mike's Avatar
Did you see this thread? https://www.evolutionm.net/forums/ec...te-thread.html
Old Apr 6, 2018 | 03:34 PM
nor11384's Avatar
FCOTM Winner
yes I saw it but couldn't figure it out...I'm using 1byte...
xPRimNT
157
Dec 26, 2018 08:09 AM
Edik_898_
Nov 28, 2016 02:02 PM
jcsbanks
Jan 19, 2008 09:01 AM
