Tuning for Kelford 272 Cams?
Old Oct 16, 2019 | 01:54 PM
BeastlyFX's Avatar
Hey there,
I recently put Kelford 272s in my friends EVO 9. I was curious as to how I might tune his car to run with idle lope, and how to give it the proper timing up top to use the cams. The car started and runs great with the cams, but has little lope and almost no top end improvement.
any tips?
Old Oct 19, 2019 | 09:47 AM
Project_Broke's Avatar
Adding lope at idle is simple, decrease timing and/or fuel. MIVEC in the -10+ range will also help get an aggressive lope.
This can and will cause drive ability issues that will have to be tuned around.
To take full advantage of the cams, a full remap will be needed, timing will increase or decrease depending on the setup and it will need more fuel.
Old Oct 19, 2019 | 11:57 AM
BeastlyFX's Avatar
Thank you
Thanks for the tips, MIVEC under idle seems to be 0 on the stock map. AFR 14.7 under idle. Idle speed is set to 750 93 degrees and higher. I’ll do a few adjustments and see what I get.
12WWGSR91
Dec 20, 2014 10:07 AM
adWRXi
Dec 6, 2011 04:37 PM
kemoly
15
Jul 2, 2010 10:13 PM
cpdevo31
29
Nov 18, 2005 08:28 PM
evo_ik
Mar 9, 2005 10:30 PM
