Will MN168749 (Evo 9 ECU) work with USDM Evo 9
I've been searching the forums and found 2 hits on the part number but couldn't find an answer if it is compatible. My plan is to flash this with tephra mod and add a flex sensor but I'm unsure if this would work for my Evo 9? Are the pinouts the same as the USDM variant and will i be able to use ecuflash? Thanks guys in advance
musicmze
Apr 25, 2016 02:24 AM
