How to control false engine knock
Old Jul 27, 2021 | 02:28 PM
Arham's Avatar
Hello.
I have a evo 7 and i have rebuild my engine to a 2.2 stroker and suffering from knock ever since
I tune the car myself and having problems with it. I am using aem series 2 engine management
does any on have a solution to this knock problem? or did someone else had a similar problem
Old Jul 28, 2021 | 06:15 AM
Project_Broke's Avatar
Monitor with DET Cans if possible, or add and remove timing to verify false knock,
Up the knock sensitivity settings as needed to alleviate.
Old Jul 29, 2021 | 09:32 AM
Arham's Avatar
I have been messing around with the timing for quite some time now and the knock i am reading is way to crazy it sometimes peak to a tremendous amount it goes to a point where it isnt even physically possible like 730 and then jumps back to 5 then 700 then 5 its like this
Old Jul 29, 2021 | 09:38 AM
Biggiesacks's Avatar
Is anything banging around? Stuff hitting into other stuff when the power surges can trigger false knock.
Old Jul 29, 2021 | 12:09 PM
Arham's Avatar
The car is old but the engine is rebuild and it has only been a year since the rebuild and whenever I floor the throttle and it hits 5000 rpm (note: our boost comes at 6300 on street) it wont stop knocking till the limiter
Colten Matthews
Apr 13, 2021 02:07 PM
bacquerel
Jul 24, 2014 12:58 PM
mxjs
Apr 16, 2009 02:56 PM
tbutterfield
13
Apr 17, 2008 04:08 PM
sharkm87
Feb 11, 2008 09:35 PM
