Major Self-Service (Fluid Flush)
Old Jun 1, 2022 | 05:44 PM
DeletusFetus's Avatar
Hi All,
Sorry if this has been posted a million times but I'm relatively new to the DIY scene and have recently purchased my first Evo (Evo 8).
I'm going to do change of the coolant, oil, trans fluid, diff fluid and spark plugs.
I'd like to know what you guys use/recommend and also if there's any other fluids/things I should look at replacing for the first major maintenance.
Am looking to bring the Evo to an Evo specialist after this to get a full rundown, but wanted to shoot a message here first before I get started.
Thanks guys!
P.S I'm located in Australia - Melb
Old Jun 6, 2022 | 09:13 PM
HyperDisorder's Avatar
I just did mine a few days ago and live in the same region and maybe have the same spec Evo, so here's my list:
Engine oil: Penrite HPR5 5w40
Gearbox: Penrite Progear 75w85 GL-4
Transfer: Penrite Progear 75w90 GL-5
AYC rear diff gear side: Penrite Progear 75w90 GL-5
AYC rear diff hydraulic side: Penrite ATF
ACD/AYC reservoir: Penrite ATF
Brakes: minimum DOT 4
Indicator fluid: Flow Designs 100HC Indicator Fluid (Concentrate)
I have an Evo 8 GSR, so has ACD and AYC, which is the same for NZ/AU/Japan spec cars.
trboboost91
Jul 22, 2012 06:58 AM
Antonovich
Oct 14, 2010 02:02 PM
Kilratio
20
Feb 9, 2007 03:27 PM
