Engine temp issue
Old Sep 22, 2022 | 04:43 PM
dsmtalontsi95's Avatar
Engine temp issue
Possible coolant temp issue. My car has been sitting for a while. I went to start it just to let it idle and it wouldn't start right away. After a few tries it would start and run for about1 second and shut off. I couldn't keep it running unless i press the trottle in and out. I did a quick scan and it looks like the engine temp is -74. The temp doesn't move. The dash gauge works as it should. I searched around and didn't find much on these going bad. Has anyone else seen this before?
Old Sep 23, 2022 | 05:42 AM
schuhie's Avatar
Sounds like the coolant temp sensor or wiring is bad. I would be looking hard at the wiring given the car has been sitting and we all know how mice can be.
The dash uses a different sensor than the ECU so it makes sense the ECU is seeing one thing and the dash another.
Old Sep 26, 2022 | 07:10 AM
Biggiesacks's Avatar
A bad coolant temp sensor would certainly explain the poor starting. I don't think its very common for them to fail, but it does happen. There are 2 sensors on the thermostat housing. One for the gauge and one for the ECU. You might want to make sure they are both plugged in and there isn't a ton of corrosion or damage to the wiring harness or connectors.
Other than that, replace the sensor and go from there.
stunt2
May 20, 2015 10:59 AM
babaz7
May 6, 2013 07:44 AM
evil_son
12
Aug 18, 2008 08:29 PM
CMcraz23
Lancer Troubleshooting
20
Feb 21, 2008 06:54 PM
05BlackEVO
May 13, 2006 12:07 PM
