Can Evoscan read raw serial data through an arduino?
Old Oct 7, 2023 | 09:36 AM
jetjockeyjosh's Avatar
Ok. So I know I’ve gone about this in a totally weird way, but it’s all I could think of to get it to work. I’ve got a prosport wideband with only an analog output (no serial output). I’ve also got an EVO 5 with the stock ECU and a custom ROM. I already have my ADC’s used for logging boost, clutch switch and map switch. This leaves me with no where to log my AFR.
My idea was to learn some light programming and use an arduino to interpret the analog signal from the wideband controller and convert that into a serial output. I was able to achieve this. I even have all the calculations for AFR in the program. Hooked it up to my laptop and everything is spot on when looking at it through the IDE software or other serial monitors. But now I have another problem.. how can I get this to log through Evoscan?
My thinking is that Evoscan has no way to interpret a raw serial data stream, so I wanted to know if there was a way to change this or if I can tell my arduino to mimic one of the wideband controllers that Evoscan DOES support.
Does anyone know what code I would need to do either of these? Or can someone share what their wideband outputs into a serial monitor so I can try to mimic that? I’m new to this so I would need all of the information, protocol, speed, etc. just everything that actually goes through the cable.
Attached Thumbnails Can Evoscan read raw serial data through an arduino?-img_1912.jpeg
Old Oct 8, 2023 | 12:04 PM
HyperDisorder's Avatar
Check the very bottom of this saved page from the Innovate Motorsports website (thanks to the Wayback Machine) https://web.archive.org/web/20130805...om/support.php
See the very bottom of the page for "Innovate Motorsports Serial Protocol 2 and Serial Protocol Supplement". Hopefully that's all that you need!
Old Oct 9, 2023 | 06:46 AM
schuhie's Avatar
Here is what I used with EvoScan to solve the same issue but with an AEM gauge that has analog output only.
https://www.dlpdesign.com/usb/io8.shtml
This serializes the data and then you just have to enter the equation in the gauge documentation to get the right values and EvoScan is already setup to use this protocol. I use this board to log my wideband, boost and oil pressure gauge without issue.
Old Feb 16, 2024 | 05:47 AM
Thanks a bunch! I’ve been trying to get what I can from the innovate page but still having some issues. Falling into one of those “I don’t know what I don’t know” kinda deals. lol with that other usb converter, what input did you choose in Evoscan? I was able to serialize by data but I just can’t get Evoscan to see it because I only have the wideband available at the top which require different kinds of protocols, packet identifiers and packet lengths.
Old Feb 20, 2024 | 08:23 AM
schuhie's Avatar
I can check tonight how I set it up in evoscan. I don't remember it being difficult though. I thought there was a serial input selection in one of the menus.
Old Feb 21, 2024 | 03:08 PM
schuhie's Avatar
So in Evoscan, under the logging menu, I have the option to select a COM or USB device. That's how I selected the DLP-IO8 and then the inputs show up in the data log window where you can edit the equations and everything
FckingTrippy
Sep 17, 2021 01:09 AM
AndyStacy
Jun 17, 2009 08:49 PM
TwoFour
May 9, 2009 12:01 PM
shuttlegoose
Aug 12, 2008 06:51 AM
Evo Singh
Jan 9, 2007 10:09 PM
