Low speed buck/cough, odd timing values?
Old Apr 6, 2024 | 08:21 PM
MikeDizz's Avatar
Unhappy Low speed buck/cough, odd timing values?
Hey guys, picked up this car a little while ago,
. Noticing at low RPMS seems like power is low. It will also buck/cough from time to time and when its cold its almost undriveable. Car needs to be retuned but STILL waiting on my tuning so in the mean time I figured id address the part throttle drivability. Comparing to the stock rom the low load ignition tables seem very harsh as far as changes go, Is this normal or should i work on smoothing? Car runs on e85 only, s3 cams, built motor 9.1 compression, AGT64mm, FIC2150cc
I am still fresh in the tuning world so i figured this is a safer area to start messing with and leave the Big power section to the Pros.
fireroasted
Sep 16, 2012 08:08 AM
silverstream
May 11, 2009 04:11 PM
silverstream
Jan 18, 2009 05:38 PM
JohnBradley
E85 / Ethanol
Oct 20, 2008 01:43 PM
dryad001
Dec 2, 2005 12:25 PM
