Evo 8 ADM Stock ROM 96530006
Hi All,
Looking for the stock ROM file for a 2005 Evo 8 Australian model.
ECU ID: 96530006
I have already searched and cannot find it. Any help is appreciated.
Thanks,
Chris.
ECU ID: 96530006
Thanks,
Chris.
Thanks
Do you know if this is actually the correct ECU id for a stock AUDM model evo 8?
It says EDM Evo 8 and "Universal" VIII ROM for rom ID: 96530006
I am basically trying to find out if this ecu has been flashed. Because it should be stock.
I've already verified the fueling is slightly leaner (~9.3 to ~10.2 AFR at WOT).
And the boost has slightly increased.
Also, Timing has been slightly adjusted.
Thanks
Thanks
Thanks
Thanks
Thanks
Index of /mirror/svn/roms/stock/8/
these should all be stock roms without changes.
Did you check in here as well
Guess it confirms I have the correct AUDM rom on the ecu. But it looks like a minor tune, stage 1 maybe.
I was confused because the ROM has no gear specific info (which is normal). But when I grabbed tephramod v7 96530706, it has Manual 6 speed by default.
But I have a 5 speed.
I am new to the platform and it threw me off.
