Knock
Old May 19, 2004 | 04:50 PM
Fas4dr's Avatar
Knock
What kind of knock activity are you guys seeing on the commander? I have seen as high as 84 and I am wondering if this is normal.
Old May 19, 2004 | 05:04 PM
chickenbrest's Avatar
My SAFC II show Knock between 0-15.... I try to use Sunoco 94 ocatne most of the time
Old May 19, 2004 | 05:06 PM
Oh, I hear that 25-70(cold) and 100-190(Hot) are normal or at least what most people see.
Old May 21, 2004 | 07:44 AM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
You want to avoid anything over 60. That is where the stock ECU starts pulling timing is what I was told.
Old May 22, 2004 | 06:56 AM
Fas4dr's Avatar
Actually I've noticed that the Power FC will not throw the knock warning light for any value under 50 and over 60 I can hear the car ping.
So to answer my own question and to validate what robertrinaustin said, keep the knock sums under 60, probably I would say in the 40 range would be safe unless someone else knows otherwise.
Old May 22, 2004 | 11:00 AM
Coolguy949's Avatar
Shouldnt the CEL come on when you're knocking on the Power FC?
Old May 22, 2004 | 08:24 PM
I'm not sure if the Power FC does this. I know it will flash when your injector duty cycle hits 100%. I'll read the owner's manual tonight and see if I can find the answer.
Old May 23, 2004 | 09:22 AM
Fas4dr's Avatar
It does, there are two different warnings, one flash sequence for knock and another for 100% injector duty cycle. It seems to be true knock that it shows, not like the SAFCII.
Old May 23, 2004 | 06:41 PM
Good. I don't have to read the manual.
