just got back from track - ran MJ's map
Old Jul 8, 2004 | 10:24 PM
Wizard_of_Evo's Avatar
running my mods and MJ's fuel and bosst map, with ecu timing. not bad results.
85 degrees 85% humidity - 300lb driver and total factory trim (spare etc...).
3 runs almost exactly the same.
60 - 1.832
330 - 5.427
1/8 - 8.405
mph - 83.29
1000 - 10.981
1/4 - 13.139
mph - 104.69
other runs were 13.197 & 13.148 all at 104.xx
aliitle dissapointed in the 1/8th - wanted to see 8.20.
lose a little weight, and get a little better launch and i will be in the 12's.
i cant wait to see what will happen once i get my wideband and really put a good tune on it.
marc
Old Jul 8, 2004 | 10:54 PM
maikonkun's Avatar
What did you run before you put the utec on ? Assuming similar mods apart from the utec.
Old Jul 8, 2004 | 10:59 PM
never ran the 1/4. just the 1/8th. 8.795 was my fastest stock. keep in mind i am flying blind as far as a/f until i get my WB.
Old Jul 9, 2004 | 08:18 AM
MalibuJack's Avatar
Very nice.. Just so you know, once you get everything dialed in, and you can check your afr's your combo should be good for a 12.8 or better..
SLVRNBLK
Jun 18, 2015 06:44 PM
MJ23FE
Sep 29, 2009 02:16 PM
wtmodnar
Mar 18, 2009 06:28 PM
BluEVOIX
Apr 22, 2008 07:04 PM
EvilAWD
Jan 18, 2007 09:44 PM
